Oil Filter Dump.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-16-2006, 08:09 AM   #1 (permalink)
View perfpump's Photo Gallery
Oil Filter Dump....
I'm sure somebody can help me out here.....When changing the oil and filter on my 94 V6 (I think it's 1Mzfe), how do I avoid the oil dumping out of the filter as I unscrew it from the engine? Is there a trick other than stuffing a rag underneath it?
perfpump is offline   Reply With Quote
Old 02-16-2006, 08:25 AM   #2 (permalink)
The 6"4 Viking
Zandro's Avatar
View Zandro's Photo Gallery
Take a Phillips screwdriver and tap a hole in the top of the filter
and wait a couple of minutes, works for me.
Zandro is offline   Reply With Quote
Old 02-16-2006, 08:41 AM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
you can try waht Zandro said or sometimes you can just loosen it slightly and it will drain somwhat before removing it all the way. there are check valves in the filter to help prevent the oil from running out while sitting. This is to help keep oin in the filter so when you start it there is already oil in it. It is a PITA as far as clean up is concerned but better than not having any oil flow on start up.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 02-17-2006, 07:59 AM   #4 (permalink)
Thanks
Thanks, I will try the screwdriver...I have loosened it and waited, but still get considerable amount spilling once i spin the filter off. Screwdriver and lots of rags next time!!
Old 02-17-2006, 02:07 PM   #5 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
or have catch pan under it, and drive screwdriver all the way through. top hole breathes, while bottom drains. -posibility.
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 02-17-2006, 02:11 PM   #6 (permalink)
View vetmx1's Photo Gallery
Been there, done that.
Nothing I know of works.
Just a pan below and rags.
A replacement head pipe doesn't stink as long as the stock unit does.
vetmx1 is offline   Reply With Quote
Old 02-17-2006, 02:22 PM   #7 (permalink)
Gameroom cash: $304355
I just spray mine with brake clean after removing the filter. It is a mess, but brake clean usually washes it away.
Mike
Old 05-14-2006, 11:26 AM   #8 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
See my signature for my car.
Even though I have a 5S-FE, I have the same problem.
I loosen the filter a bit, then tap it with a plastic mallet.
Using this method, I make a mess only about 1/3 of the time.
Go figure!
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Old 05-14-2006, 11:44 AM   #9 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397185
View RningOnFumes's Photo Gallery
do it in the morning after the car has been sitting all nite?
There's still oil, but minimal
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is online now   Reply With Quote
2005 Avalon XL Oil Filter anndel 3rd Generation (2005-2012) 9 04-01-2008 06:04 PM
Full synthetic motor oil - 32¢ /quart + 1 oil filter ... Pep Boys skewe General Discussion 7 01-19-2006 03:31 PM
Solara 5S-FE oil filter removing. (Dumb) SolaraTRD Solara 20 01-24-2005 11:54 AM
Oil Filter Wrench BenG Hardcore Tech and Competition 12 07-22-2003 10:01 PM
