my car rocks back and forth after i let go of foot brake on driveway ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-16-2006, 03:10 PM   #1 (permalink)
View AyzhenInvasion's Photo Gallery
4th Generation my car rocks back and forth after i let go of foot brake on driveway ?
so when i drive up my driveway, put it to park, turn off engine, and let go of the foot brakes, the car starts to slide back then forward, then back and forward a few more times ??
when this is happening, the engine/tranny starts to rotate (as if it is connected to the wheels and not the car frame in sync with the wheels small movements of foward and backward.
mounts dying ? or is this engine movement normal... ?
AyzhenInvasion is offline   Reply With Quote
Old 02-16-2006, 05:30 PM   #2 (permalink)
Gen 4 Snow Lover
View randomman84's Photo Gallery
parking brake. the ground isnt level so the wheels are rolling back on the brakes solution: parking brake. That rocking is bad for the tranny
Gen 4 to Gen 4.5 FEC (Front End Conversion) Complete!!!!! Pics Below!!
Official DIY (Kinda)
http://toyotanation.com/forum/showth...389#post856389
randomman84 is offline   Reply With Quote
Old 02-16-2006, 05:42 PM   #3 (permalink)
View newbie212's Photo Gallery
Same thing happened to me... It's most definitely ur mounts.... 2 of mine were shot... Living in boston for 5 years, the road salt took its toll on my mounts... Check those first.. I replaced em myself.. I remember one of them being a total bitch.. Hope this helps..
newbie212 is offline   Reply With Quote
Old 02-16-2006, 08:10 PM   #4 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
I second that. The parking brake is your main parking device. The park position of the transmission is only a back-up / assist.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 02-16-2006, 08:46 PM   #5 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
why would it be the mounts? the tranny locks in at a certain point, if your past the point, it will roll to the point... its momentum that causes it. i just lock my parking break before i shut off the car.
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 02-16-2006, 08:48 PM   #6 (permalink)
but when i put the hood up, and i start rocking the car back and forth, the engine/tranny seems to move with the wheels and not the car frame...
when the car moves back, the engine/tranny tilts back, when it rocks back up, the engine/tranny tilts forward... is this suppos to happen ..?
Old 02-16-2006, 09:15 PM   #7 (permalink)
yah ..... okay
View Neon's Photo Gallery
Is your driveway on an angle ????
it should be normal, when you turn off the car and let the brakes go, you should hear a click.
i think becasue your "P" drive could not fully lock up your car on an angled driveway. next time try to pull the e-brake and then let the foot brake go =)
*Image removed. Too big. You know the rules!* -Phi
Neon is offline   Reply With Quote
Old 02-17-2006, 12:08 AM   #8 (permalink)
solarinsocal's Avatar
View solarinsocal's Photo Gallery
Your parking brake isn't actually doing anything. The rocking back and forth you see is the give in the engine mounts which means that the weight of the car is resting on them if the car is on an incline.
2007 Avalon Touring
1994 Camry Wagon LE V6
1994 Supra Turbo
solarinsocal is offline   Reply With Quote
Old 02-17-2006, 03:56 AM   #9 (permalink)
I'm telling you, its the mounts... I had the same problem and thought it was the parking brake...
Old 02-17-2006, 04:04 AM   #10 (permalink)
N/A bites
Tercel GTS's Avatar
I agree you need mounts, plus you need to improve your parking on an incline skills so you don't damage the new mounts.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 02-17-2006, 05:28 AM   #11 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
View terrynham's Photo Gallery
i agree with you
as far as i know, it is normal, my car does it too, every car ive driven did it aswell
its because you didnt put your Parking Brake on...
if you did, it will stop the car from moving when you let go of the brakes.
but since you only put it into Park, the car now relys on the transmission to stop it
the transmission does NOT 'lock' the wheels into place like the parking brake does...
it has a bit of 'give' before it actually catches the car from rolling away.
when it does catch the car, the momentum caused by the small movement causes the transmission to take the weight of the car and then rebound it a bit, thus giving you that rocking forward and backwards.
~ Terry
terrynham is offline   Reply With Quote
Old 02-17-2006, 05:54 AM   #12 (permalink)
Australian TN'er
View Phat Devil's Photo Gallery
^^ yup what terry said is right on. All you need to do to stop it is to pull your parking brake up higher/ engage it properly to stop it from rocking back and forth.
When you re-engage the car back into drive, it would sound like at *crunch/thump*.
Phat Devil is offline   Reply With Quote
Old 03-16-2006, 11:54 AM   #13 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
I'm bumping this thread because that's exactly what my '98 Camry is doing and it annoys the fuck out of me.
The car seriously wobbles back and forth even if I try to go easy when I release the brake pedal. It makes little to no difference if I release all of a sudden of real smoothly wich makes me think it's a bent metal thing that gets the pressure and throws the car back when the weight sits on it.
It could very well be the mounts but the question is : is there different sets of mounts for engine and tranny or they're all held up by the same parts, wich would make me change the mounts all around?
I'm using the handbrake in the meantime.
Maim Menu is offline   Reply With Quote
Old 03-16-2006, 01:40 PM   #14 (permalink)
from now on i'm always gonna use the parking brakes when parking on a slope but the thing is... when i DO actually go back and forth.. the engine rocks back and forth.. like.. thats NOT normal is it ?? thats why i thought it was the mounts...
Old 03-16-2006, 02:28 PM   #15 (permalink)
Moving Forward
View Cyorke's Photo Gallery
It is normal for the engine to rock to some extent when you put it in park and release the foot brake. You ahve a car that weighs in excess of 1 1/2 tons. Do you really think that it is ont going to move some. When you put the car in park the only thing that is holding it in place is waht is called a parking pawl. It is a small latch.lock type mechanism inteh transmission. When you put the car in park it is not going to be lined up exactly on teh parking pawl. The trans is going to rotate a certain amount until it hits this pawl. when it does the car is going to rock because of the weight of the car. It is completely normal. GO get in any new car and park it ona slope of any angle and put the car in park without setting the parking brake and it will roll and the engine will rock to some extent. The only way to combat this is to set the parking brake before you release the foot brake. ONce you set the parking brake and release the foot brake the car is till going to move slightly though. There is no way around it. That is jsut part of physics and gravity and all that other good stuff you learned in basic math classes.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
94 Lexus ES300 Starting Problem starry012 General Lexus Discussion 0 10-03-2005 01:21 PM
can the 05 corolla starting problem hurt your engine??? Salduchi1785 Archived Corolla threads 9 03-29-2005 07:11 AM
Hard to move from Park to Reverse fruto123 Camry & Solara Lounge 13 07-12-2004 08:02 PM
Starting problems - Electrical. pdrover Archived Corolla threads 12 02-09-2004 03:55 AM
