New Electrical Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2006, 09:06 AM   #1 (permalink)
View MattSWE's Photo Gallery
2nd Generation New Electrical Problem
whenever I have my cd player on and I hit the brakes 2 out of three times the cd player will cut off and then come back on. Plus my power locks wont work now, yesterday everything was fine and now this, what could it be??
MattSWE is offline   Reply With Quote
Old 02-17-2006, 11:02 AM   #2 (permalink)
View DoomCrewInc's Photo Gallery
check for blown fuses, and recheck the wiring to your cd player(assuming it is aftermarket)
1990 Camry DX I4 3S-FE Automatic: Few Mods: Custom Intake, Custom Cat Back, 17" Panther Wheels W/ 205/40 17 Falken Tires, Reverse Glo Guages,*still gathering parts to boost*
***Need turbo manifold w/adapter for T4***
Email: Infinitemotorsportslc@hotmail.com
DoomCrewInc is offline   Reply With Quote
Old 02-17-2006, 12:02 PM   #3 (permalink)
2nd Generation
it happens when I reach 2k rpm's and anything lower you can see the cd player dim and the same with gauges i installed too. everything dims when I brake? Is that something to do with the alternator?
Old 02-17-2006, 01:02 PM   #4 (permalink)
View mspringer's Photo Gallery
I doubt its the alternator (although that is easy to check with a multitester - try autozone if you do not have one).
My guess - your wiring. I would check the ground - did you ground directly to metal, or to an existing wire that you believed to be a ground? I would ground directly to metal.
What did you usee for power (+12v)? An existing wire, or the battery? I would (at least temporarily) hook the CD player and gauges directly to the battery, and see if that fixes the problem. If it does, relocate your positive lead for the lights and stereo.
mspringer is offline   Reply With Quote
Old 02-17-2006, 02:29 PM   #5 (permalink)
Gameroom cash: $304355
I would guess you have a marginal alternator. When you hit the brakes you are also turning on the brake lights and at the same time the alternator is turning very slowly (idle speed). Check the output of your alternator with a DVM. Even at idle it should be above 14 volts.
Mike
Old 02-17-2006, 04:21 PM   #6 (permalink)
2nd Generation help
I went to AutoZone and they checked my alt and battery and all is good. Today I started it ut and it ran for 2 seconds then EVERYTHING shut off. Had to wait 10min before it started again. The problem now, is that if I try to start it right after its been running, it wont start, the car has to wait.
Old 02-17-2006, 11:55 PM   #7 (permalink)
Fixed
I cleaned the positive battery terminal and damn, now it starts way strong and everything is awsome again! thank god
HELP!! electrical problem during boost gauge install... fallingsux MR2 Forum 2 08-17-2005 05:33 PM
1998 Avalon XL Interior Light (Electrical) Problem WeiT 1st Generation (1995-1999) 1 06-06-2005 03:55 PM
1987 camry- electrical problem? thecornking 1st & 2nd Generation (1983–1986 & 1987-1991) 8 01-18-2005 10:00 PM
83 Celica Supra GTS electrical problem MrPipes Celica Forum 3 08-14-2004 04:21 PM
90 Corolla Electrical Problem lpbaca Archived Corolla threads 0 11-15-2003 08:51 AM
