P0340, Camshaft Position Sensor Malfunction. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2006, 11:02 AM   #1 (permalink)
mj.
View mj.'s Photo Gallery
Can i continue to drive my 97 cam 4cyl with this engine light code. Will I mess anything up. How do i correct it? how much would it cost
P0340, CAMSHAFT POSITION SENSOR MALFUNCTION.
mj. is offline   Reply With Quote
Old 02-17-2006, 12:49 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The cam position sensor is important. Your car has DIS (distributorless ignition system) and uses a crank & cam position sensor to determine when to fire.
I'd bet that your ignition timing is retarded (no pun intended) cos of the malfunctioning cam position sensor.
Get it fixed ASAP.
"Skoolin' the unlearned!"
Old 02-17-2006, 01:21 PM   #3 (permalink)
mj.
The only problem I am having is a rough accelation of of 1st gear, after that it runs fine. What do i need to replace?
Old 02-17-2006, 01:26 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
^ Well, the cam position sensor for one, if it is indeed malfunctioning.
Other then that I couldn't tell you. Take it to a mechanic and have them look at it.
Old 02-17-2006, 02:26 PM   #5 (permalink)
mj.
anybody have a diagram or picture of this part. What does it look like. Where is it located. I had a major oil leak and my mechanic change my oil pump, waterpump, timing belt, crank and cam gaskets along with the top and bottom gaskets on the engine. Did he fowl something up. Can I wiggle this senor in place to see if it "kicks" on
Old 02-17-2006, 04:58 PM   #6 (permalink)
Grenaded piston
88 LE's Avatar
http://autozone.com/servlet/UiBroker...3d8013edb5.jsp
The sensor shouldn't wiggle. I wouldn't mess with it if you don't know what your doing.
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
OBD Code Camshaft Sensor, but There Isn't One! Jeff_M_PA Camry & Solara Lounge 9 10-19-2006 06:12 PM
1MZ-FE camshaft weirdness m4663 Hardcore Tech and Competition 16 11-28-2005 02:28 AM
5sfe camshaft position sensor HELP PLEASE!!!!!!!!!!!!!!!! 04rollacompadre 3rd & 4th Generation (1992–1996 & 1997–2001) 2 11-13-2004 04:36 PM
