Wheel & Tire Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2006, 01:13 PM   #1 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
View RICO8458's Photo Gallery
Gen5 Wheel & Tire Question
My neighbor is going to put on 215/70/15 on his Camry. i told him he is better off upgrading his rim size. i explained that with that sidewall height he will sway way too much when turning the car at high speed. question is : is there any danger in this combination? thanks mates.
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline   Reply With Quote
Old 02-17-2006, 01:28 PM   #2 (permalink)
View kevintomb's Photo Gallery
not dangerous...really. Its just not going to make quick maneuvers as responsive. Ive got 205/70/15 on my car...went up a bit from the 65 series sidewall..because of the poor roads where I live. It makes road imperfections a bit easier to absorb...but downside cars response is a "tad" less now. A camry to begin with doesnt exactly handle great, its more set up for comfort anyways.
kevintomb is offline   Reply With Quote
Old 02-17-2006, 03:16 PM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
it will depend on how hard he drives.. if he grandmas EVERYWHERE.. i mean everwhere as in a bicyle takes corners faster then go for it.
that much wall on a psaanger tyre is dangerous.
if you must get a light commercial tyre, although that will loose comfort it wont feel like a boat swaying while youre waiting at the lights.
remember that a 215/70 is A LOT taller then a 205/70. not to mention a 215 section tyre o a 6" rim is baaaaad.
terrastrife is offline   Reply With Quote
Old 02-17-2006, 03:46 PM   #4 (permalink)
ToyCam05
View PinoyBoy28's Photo Gallery
Gen5
first of all 215/70 is NOT taller than 205/70.. 215/70 actually a lil bit WIDER than 205/70.. u prolly mean that 215/70 is taller than 215/65..
PinoyBoy28 is offline   Reply With Quote
Old 02-17-2006, 03:49 PM   #5 (permalink)
ToyCam05
here for more info... http://www.discounttire.com/dtcs/infoSidewall.dos
Old 02-17-2006, 03:53 PM   #6 (permalink)
Gameroom cash: $199835
View swegyptian's Photo Gallery
Yes it is. Read your link again.
www.swegyptian.com
swegyptian is offline   Reply With Quote
Old 02-17-2006, 04:05 PM   #7 (permalink)
View mspringer's Photo Gallery
Its actually taller and wider.
215 is the measurement in mm from bead to bead
70 is the aspect ration- 70% as tall as it is wide
a 215/70 will be slightly taller and slightly wider than a 205/70.
However, actual numbers (measurements) vary so much from mfg to mfg, this is a largely academic discussion. You have to actually pick out the tires and physically measure them to really say that one will be taller and/or wider than another.
mspringer is offline   Reply With Quote
Old 02-17-2006, 05:52 PM   #8 (permalink)
man, he just owned himself lol =)
anyway, i would advise against mounting a 8.4" wide (215 section) tyre on a 6" wide rim. theres just not enough sidewall stretch for it to be stable (a bit tid bit... for this amount of width different you would want a tyre 1/2" smaller...hence why drag slicks are 14.5" on 15" rims.)...heck, the stock 205 section tyre size is pushing the limits of a 6" rim... the 4 cylinders got it right with their 195 section tyres...
and one last thing... i have 215/60R15's on my stock 6" rims... DO NOT like it at all...
Old 02-19-2006, 01:43 PM   #9 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
i hear that. I told him that he better just upgrade his rims to 17", then he can wear 215's or 225's. i would hate to see him fly off his rims at 70 miles on a tight turn off the highway...lol.
Old 02-19-2006, 08:50 PM   #10 (permalink)
I think that you are missing the point - the rim needs to be wider. The reason that you see people with 215 or 225 mm tires on a 17 or 18 inch rim is because they move to a 7, 7.5 or 8 inch wide rim. The rim diameter is not the main issue.
new owner problems dack41 2nd Generation (2005+) 17 10-04-2006 10:53 PM
Celica GTS wheel and tire packages Import Tire Supporting Vendor Sales 2 09-16-2005 11:16 AM
17" wheel and tire packages for the Celica, Corolla, Matrix, Scion Tc, and Prius. Import Tire Supporting Vendor Sales 0 09-15-2005 10:19 AM
Question about tire chains/cables ABTRD General Discussion 0 02-24-2005 11:48 AM
