well, since my last thread was locked, im starting a new one, my turbo wastegate, and blow off valve was received today, along with my new walbro 190 lph fuel pump, and my intercooler piping. and i have a pic to show for it, since last time i had nothing to show....
So here it is
I purchased on ebay, and this is the ebay pic, i received the items the same way as shown.
According to the 5sfte thread stickie:
Turbo (ct26 or other)
Manifold (factory 3sgte is good with the ct-26)
-I
ntercooler – 3s is not going to work on the camry – buying a good front mount will serve you well in time
Piping - this needs to be custom made… you can go the massive silicon coupler route, but welding hard pipes is going to make connections stronger
-Injectors (Supra NA) PART # 23250-70080 are often used – a 360cc+ will be good and Toyota has a few stock models there
-2bar MAP SENSOR(factory 3s) Part # 84420-17030
-Custom Downpipe must be made, the 3s downpipe does NOT WORK ON THE CAMRY with the location of the motor mount on a camry vs. mr2…)
Blow Off Valve to fight compressor surge
- Boost Gauge – even though creep is not big on the ct-26, helps out
- Exhaust work to match to DP/Cat assembly, custom fab again
Oil, Water/Coolant lines to and from turbo (3s if using ct26/mani, these can be ordered and custom fabbed though)
tapping the oil pan for oil return – Ufoz also said you CAN swap to the 3sgte pan - if you are a non-cali 5sfe
Misc. Rubber/Silicon hose for turbo fiitings…
1:1 FPR for the camry’s
- some sort of tuning management – I opted for the greddy emange, others are out there, seems like a good deal of people have the Apexi SAFC (AF) + MSD BTM (timing) to tune… this is virtal to keeping the system alive
working on this part
new spark plugs, colder heat range ( see the bottom of the post)
Options you are going to want
- Air/Fuel Ratio Gauge (wideband is what you want to tune, great investment- narrow band is not really helpful)
- EGT gauge helps for tuning also, especially in conjunction with the AF monitoring
- Oil pressure gauge (more monitoring the better)
- Boost Contoller (electronic seems to be a good investment, don’t get stupid on stock internals)
- Turbo Timer for controlled shut down of car
- oil catch can - avoid the nasty oil burn out the exhaust, catch the blowback
Metal head gasket (Toyota 5sfe metal is good)
-Af
termarket Clutch..THIS SHOULD BE A MUST! – trust me my stage I was not very good at first…
Building the motor is great, Internals, Pistons, Rods, rings etc. (if you have access to a separate 5s… a buildup outside the car will be good, then drop it in later after you have finished that up, so less downtime on the car)
