E-brake light has a mind of it's own. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-18-2006, 02:13 PM   #1 (permalink)
View Grayguy's Photo Gallery
Ik, lately when it's cold, when ever I slow down and stop, the ebrake light pops on. For a while, I could just start going again and it would shut off. Then last night I would have to tap the brake when I started going to shut it off. Then after about 10 minutes of that, it just stays on. Now this seems to only happen when's it's cold (-25F last night). So what's the deal?
Grayguy is offline   Reply With Quote
Old 02-18-2006, 02:16 PM   #2 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
mine just starting doing that yesterday. Word up to MN! Must be the frigid temps, it was -10, -15F down here in MPLS. I'm also getting a lot of suspension noise now too. Of course i went through the car wash last night so that probably didn't help! You should have seen the whirlwind where the 3 hot air blowers were mixing with the -15F outdoor air at the exit.
"Knowing is half the battle."
Color Valentine One Displays
SnakeyeS is offline   Reply With Quote
Old 02-18-2006, 02:17 PM   #3 (permalink)
TN User
View odbII's Photo Gallery
Might be low brake fluid.
odbII is offline   Reply With Quote
Old 02-18-2006, 02:30 PM   #4 (permalink)
0111010010
SnakeyeS's Avatar
^hmm can anyone else confirm this??
Old 02-18-2006, 02:34 PM   #5 (permalink)
View karazy's Photo Gallery
^ hmm, check the fluid.
karazy is offline   Reply With Quote
Old 02-18-2006, 02:35 PM   #6 (permalink)
^could probably just check it.
My suspension was actaully quieter. Then again, my struts need replaceing, so maybe the cold helped them. Driving with a clutch and tranny that barely move is fun though.
Old 02-18-2006, 02:38 PM   #7 (permalink)
N/A bites
Tercel GTS's Avatar
If the brake fluid isn't low then get the front pads checked.
But yes, check the fluid level.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 02-18-2006, 03:39 PM   #8 (permalink)
View FrankXT86's Photo Gallery
Yeah...definatly low fluid. Topped my fluid off and the light went away. Keep in mind...when the pads get more and more worn, it takes more fluid to push the piston down on the brakes. So when you change the pads next, remember that you put more fluid in or else it'll come pouring out of the top.
1999 Toyota Camry LE
2.2L I4 (5S-FE)
Mobil-1 5w-30 Synthetic
130K+ Miles
BF-Goodrich Revelation Tires
FrankXT86 is offline   Reply With Quote
Old 02-18-2006, 04:01 PM   #9 (permalink)
So why would it only do it when it's cold. I just drove my car and it didn't do it, and it's about 25F now?
Old 02-18-2006, 04:13 PM   #10 (permalink)
'96 Rolla DX
View SR5_4WD's Photo Gallery
Hey guys I have the same issue, and it is the brake fluid level, if you fill it to full, the light will not come on while braking/stopping. My resivoir leaks, so I have to deal with this about 5 times per month.
SR5_4WD is offline   Reply With Quote
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
1996 Corolla Third Brake Light BigTattoo Archived Corolla threads 6 10-23-2005 12:21 PM
Gen5 Brake Light VVT-i Owns 5th & 6th Generation (2002-2006 & 2007-2011) 2 08-25-2004 05:01 PM
brake light powderblue91 Camry & Solara Lounge 1 05-30-2004 09:17 AM
L.E.D. Tail/brake light & 3rd brake light conversion project eviltwin67 Camry & Solara Lounge 2 07-02-2003 10:24 AM
