New antenna for the Coupe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-18-2006, 03:49 PM   #1 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $910927
iTrader Score: 59 reviews
I just purchased this antenna for the coupe. Any of you guys/gals have one of these? Kinda looks like the antenna on the S2000. I'm just getting tired of repairing the OEM power antenna every couple of weeks.
http://www.antennax.com/products/Description_ax02.htm
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 02-19-2006, 06:33 AM   #2 (permalink)
Super Moderator
eyeball96's Avatar
38 views and no comments....I guess I'll be the only one with one of these...I'll do the install and post some pics when it arrives.I get to do a "product review"
98 Honda CRV
08 GMC Crew
Old 02-19-2006, 07:51 AM   #3 (permalink)
View Ruchi's Photo Gallery
3rd Generation Well, the price is right.
I just purchased and installed a "direct replacement" antenna from Antenna X. Unfortunately the unit itself was a bit different in size and shape, so I had to use tie straps to mount the unit. It works, but I'm not happy with the install (had to get rid of the OEM rubber grommets too).
I don't necessarily like the look of that EuroStyle antenna, but was honestly wishing I had purchased something like that-but shorter-when dealing with the electric ant. install. Would have saved me some money.
It looks like your car is the same color as mine, but mine is a 4 door 93 LE with 215K, purchased off ebay recently.
http://cgi.ebay.com/ebaymotors/LE-SU...QQcmdZViewItem
Good luck with the install.
Ruchi is offline   Reply With Quote
Old 02-19-2006, 08:32 AM   #4 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
Yours keeps breaking on you every couple of weeks? There's something else wrong with your electricals or maybe there's water leakage into the unit. I'm still running off my factory antenna and it's been nearly 12 years.
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 02-19-2006, 08:56 AM   #5 (permalink)
Super Moderator
eyeball96's Avatar
Thanks for the reply. Your right! I didn't pay much for the antenna 19.95 shipped. So WTF
I just don't like the OEM antenna up 3 ft in the air all the time. Have any pics of yours?
Nice find on the 93. Looks nice for the age and mileage! The color is "Magenta". One more question, where did you need to use the twist ties?
98 Honda CRV
08 GMC Crew
Old 02-19-2006, 09:33 AM   #6 (permalink)
Super Moderator
eyeball96's Avatar
Here's the deal on the antenna...It was broken when I found the car, cable broken inside the motor. I could hear the motor turning but the antenna didn't move. I bought a new mast and cable off ebay, and had it installed by my regular mechanic.(I watched and helped by turning the radio on and off) Well it worked for about a month and stopped again.
This time tho I didn't hear the motor, I removed the antenna, cable and mast and the motor ran fine. So fucked around with it, disassembly and reassembly, seemed like 10 x's while my wife turned the radio on and off. The cable would go in maybe a 1/2 a cycle then stop. When I was ready to give up, I got it working. It lasted a couple of weeks. and stopped again (no motor sound). No moisture seen!
Well I did all the things as above again, and still couldn't get it to go more than 1/2 cycle, seems its jamming, I tried more white lube, didn't work, the motor go's full cycle without the cable in it. (I'm a big guy and the trunk is not a comfortable place to work in), so I said fuck it and put it all back together and unpluged the power from it and left it up!
I hate the way it looks "up", I guess I'm anal, wife doesn't understand why it bothers me, and doesn't want me to spend alot of money fixing it. So thats the reason for the 20 buck, shorter non-power replacement. I'm worried that I may be going from bad to worse tho
Would anyone happen to know what the stealership OEM replacement motor and mast may cost? (ball park estimate)
My previous 3.5 LE antenna (daughters now) has worked 10 yrs now without a problem!
Thanks for the reply! any help is appreciated!
98 Honda CRV
08 GMC Crew
Old 02-20-2006, 03:19 AM   #7 (permalink)
Since the bolt/screw holes didn't line up with the frame holes, I just tie strapped the mast/motor to the frame. I didn't connect the rubber drain hose either, since I sawed off the nipple in an attempt to get the unit bolted up to the original mounting hardware.
I don't have a dig. camera, so no pics. It looks similar to an OEM, but upon close inspection a fellow owner would spot the difference.
Old 02-26-2006, 01:11 PM   #8 (permalink)
Super Moderator
eyeball96's Avatar
Ok, got it installed, super easy! AntennaX included extra connectors, instructions, and even an extra antenna thats a little taller with a slightly different base and stiffer! (I put the more flexable one on)
So far I the radio reception is the same, maybe better! Its definitely isn't a S2000 antenna tho! ....but for 20 bucks WTF
I guess it looks OK for now! What do you guys/gals think?
98 Honda CRV
08 GMC Crew
Old 02-26-2006, 01:43 PM   #9 (permalink)
Gameroom cash: $926800
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Sure better then the damn power prob antenna!
5 Lug Corolla WHAT?
Old 02-26-2006, 01:43 PM   #10 (permalink)
08 XR
iTrader Score: 6 reviews
View MrJones's Photo Gallery
Thumbs up nice
nice attenna, fits pretty well but im still partial to the 3 ft stocker..
LOL damn when i read that you had a daughter i was like ... is this the same guy i just did business with? i guess being a car guy removes all biases including age.. .just one thing ties us together, the love of camrys.
Originally Posted by ECale3 View Post
It's not about the destination, it's about the drive.
MrJones is offline   Reply With Quote
Old 02-26-2006, 02:02 PM   #11 (permalink)
Super Moderator
eyeball96's Avatar
Yea, I guess I've been a car guy alittle longer. ..........
I didn't hate the 3ft stocker! I just didn't marry a "car gal".....she doesn't understand me buying things for the cars/truck....unless it "on sale"
98 Honda CRV
08 GMC Crew
Old 02-26-2006, 02:10 PM   #12 (permalink)
I don't sugarcoat!!
View camrycoupe95's Photo Gallery
Hey man, same antenna problems with my 95 Coupe. Took it apart and replaced the cable, still didn't work right. So I disconnected the power and left the 3 ft stick up in the air. Looking for a used OEM replacement, I refuse to spend $200 or whatever a new OEM unit costs.
But you introduce an interesting alternative with that whip unit......
1985 AW11
Past Toyota products --1989 Corolla SR5, 1995 Camry LE Coupe, 2002 MR2 Spyder, 2006 Scion xA
camrycoupe95 is offline   Reply With Quote
Old 02-26-2006, 02:51 PM   #13 (permalink)
Super Moderator
eyeball96's Avatar
Check out AntennaX.com...........The cheapest site I found for an OEM unit, including the mast, was ToyotaPartscheap.com. (they say they only sell OEM parts) They were asking 124 and some change, but shipping was high!
But like I said for 20 bucks, It'll do for now! I have to get use to the way it looks!!
98 Honda CRV
08 GMC Crew
Old 02-26-2006, 04:20 PM   #14 (permalink)
Carzz R Xpensive!!111
felkajamine's Avatar
iTrader Score: 11 reviews
View felkajamine's Photo Gallery
won't see me with one lol, shaved my whole thing off, never worked anyway.
looks nice though man, nice buy!
'95 5spd Scepter Coupe
felkajamine is offline   Reply With Quote
Old 02-26-2006, 04:48 PM   #15 (permalink)
Super Moderator
eyeball96's Avatar
Thanks What do you use for an antenna?
98 Honda CRV
08 GMC Crew
Avalon Pre-Wired For Sirius?? ROBTN 3rd Generation (2005-2012) 16 05-06-2009 06:07 PM
Can't get stations... Antenna help!! nat77 Camry & Solara Lounge 10 05-17-2005 10:24 PM
Replaced my antenna Stealth Camry & Solara Lounge 2 04-08-2003 07:49 PM
S2000 Antenna HELP! phat555 Camry & Solara Lounge 25 01-25-2002 07:00 PM
