Anybody running custom alignment settings - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2006, 09:59 AM   #1 (permalink)
macr88's Avatar
View macr88's Photo Gallery
4th Generation Anybody running custom alignment settings
Just curious if anybody has any good numbers for a 98 camry.
Camber
Caster
Toe
I used to run about 1.75 degrees negative camber until I replaced all bushings and
struts now I'm running .7 . I don't think I like it though. Caster and toe are within
factory spec.
Thanks
Mac
macr88 is offline   Reply With Quote
Old 02-19-2006, 02:24 PM   #2 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Lightbulb All depends how often you want to replace...
Those are nice numbers (1.75) but are very hard on tires for a street driven (not road raced) car.
I can only invision about 2000 miles on a set of tires before the inside in blown away. But it would stick nicely in the corners for rr.
For street use I wouldn't go past -0.5 camber. And the weight bias of the camry, prob like -0.25 front and -0.5 back. Don't think you can do much with caster but if you add about a quarter more on the right, it well help it go straight on the crowned roads (more comfortable daily driver).
Most of us need a zero camber/zero toe to get mileage out of our tires.
Do tell us how you actually use the car.....
Regards,
Randy
73sport is offline   Reply With Quote
Old 02-20-2006, 02:41 AM   #3 (permalink)
macr88's Avatar
I use the car for fun.
Just got done doing 300 or so miles of abuse.
The 1.75 with my old setup wich was only tokico
struts was fine on tires. I wore the outside just
as much as the inside.
Since I got rid of most of the rubber I figured
I'd go a bit less on negative camber but I'm
thinking after today 1.0 would be better on
my tires.
Thanks
Mac
Rear wheel alignment problem on 2004 corolla S Fv53 Archived Corolla threads 1 02-19-2006 07:50 PM
Steering rack boots torn into two pieces after a firestone alignment, need input ruoknow Camry & Solara Lounge 10 11-17-2005 03:39 PM
Alignment in the Bay Area Paul Mcmenamy MR2 Forum 2 04-22-2005 09:03 PM
Custom body-kit, anyone? mnm66646 General Discussion 14 02-06-2003 02:19 AM
Custom turbo? F1 Chris General Discussion 6 10-17-2001 05:58 PM
