Camry V6 LHS Driveaxle Removal - Toyota Nation Forum : Toyota Car and Truck Forums
View Poll Results: Sorry - poll was a mistake - please ignore
rt 0 0%
rt 0 0%
rt 1 100.00%
rt 0 0%
Voters: 1. You may not vote on this poll
Old 02-19-2006, 01:01 PM   #1 (permalink)
View davidf's Photo Gallery
Question Camry V6 LHS Driveaxle Removal
1995 Camry with 1MZ-FE engine and automatic transmission. Trying to remove LHS (USA Driverside) driveaxle. Driveaxle is removed and free from wheel hub and I am now trying to pull driveaxle from differential. (I have removed the six 'allen key' bolts from the inner CV joint as per Haynes manual).
Problem - cannot pull the driveaxle from the differential. Have tried prying the inner CV tulip with prybar to no avail. Anyone had similar problem and found the trick to remove the driveaxle?
Thx
davidf is offline   Reply With Quote
Old 02-19-2006, 04:14 PM   #2 (permalink)
View green94camry's Photo Gallery
It should come right off after you remove the 6 allen head bolts from the axle shaft assembly. On the drivers side the axle bolts up to the inner shaft, all you have to do is unbolt it and the shaft should seperate fairly easily, just pull it off the inner shaft. There is no need to remove the inner shaft with the axle still attached.
green94camry is offline   Reply With Quote
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
2002 - 2005 Toyota Camry review! Lexusfreak 5th & 6th Generation (2002-2006 & 2007-2011) 2 03-27-2006 03:43 AM
Camry V6 SuperCharged VS 04 Honda Accord V6 TypeRex187 Camry & Solara Lounge 34 01-16-2005 01:45 PM
96 Camry V6 LE: TRD supercharger? kman10587 3rd & 4th Generation (1992–1996 & 1997–2001) 11 07-16-2004 03:15 PM
