Keyless remote / battery question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2006, 02:26 PM   #1 (permalink)
View joshi's Photo Gallery
We have a 2000 Camry. The original keyless remote/alarm batteries work fine in both remotes, but we are wondering how long the battteries generally last. We don't want to get stuck somewhere, unable to unlock the car because the batteries gave out. Do most of you replace these batteries every X years, or will they pretty much outlive the car?
IF you do need to replace them, a) is it a watch-type battery that you can buy at any store? b) Is it easy to do or should we have the shop do it? Any programming required? Wasn't sure if you have to reprogram the unit after swapping batteries, or if you can just pop out the old one and put in a new one like you would a watch battery. I couldn't find anything in the manual about it...
Thanks.
joshi is offline   Reply With Quote
Old 02-19-2006, 02:55 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
It most likely uses a watch type battery (CR2032), 10A, or 23A.
No reprogramming required. Just pop out the old battery and replace.
"Skoolin' the unlearned!"
Old 02-19-2006, 06:41 PM   #3 (permalink)
TN's Nikon Expert?
prnc_chrmng's Avatar
Gameroom cash: $491868
View prnc_chrmng's Photo Gallery
also, if your battery dies out, cant you unlock your car with your key?
Originally Posted by 98tercel_girlie
This thread needs more porn, less blah blah
prnc_chrmng is offline   Reply With Quote
Old 02-19-2006, 07:29 PM   #4 (permalink)
Yes, could unlock with key, but I wouldn't know how to shut off the alarm in that event. It's a keyless with alarm.
How often do most people replace that battery?
Old 02-19-2006, 08:12 PM   #5 (permalink)
TN's Nikon Expert?
i replace the battery in my aftermarket alarm like every 3 months, and my OEM one....maybe once in 4 years. your alarm should probly go off after your start your car, or put your key in the ON posistion. maybe you should give it a try now so you know incase it should ever happen.
Old 02-19-2006, 09:33 PM   #6 (permalink)
The Camburger
iTrader Score: 6 reviews
View Admiral's Photo Gallery
there may be a kill switch too that you have to press while you try and start or it will just turn and nothing will happen. definately do what prnc_chrmng said and try it out now. also, all the alarm remotes i ever had used this weird sized battery. not a watch battery, it looks like a short AA battery. just unscrew it and check it out so you are prepared if you need ot be.
Admiral is offline   Reply With Quote
Old 02-19-2006, 09:35 PM   #7 (permalink)
TN's Nikon Expert?
hmm iv only seen that weird one with my garage door opener. my OEM alarm remote uses a watch type batt.
Old 02-20-2006, 05:30 PM   #8 (permalink)
Gameroom cash: $304355
We have never replaced either of the batteries in my wife's 98 XLE remotes. It came from the factory with the Toyota alarm system.
I replaced the battery in my aftermarket remote for my 94 twice. Once with a Radio Shack battery when I was on a trip and it when out. Then a year later, when it started acting up again and I took it apart and noticed that acid was leaking out of that Radio Shack battery. That was about 3 years ago and it is still working fine.
Mike
Old 02-20-2006, 08:29 PM   #9 (permalink)
I took it to the dealer tonight and the guy replaced both of them for me. The batteries he used were Rayovac CR2032 lithiums, looked like a large watch battery. Hope it lasts as long as the first ones did... not sure what was in there before.
Compilation: Programming Remote entry for GEN4 camry keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 36 09-05-2009 11:54 AM
installing remote keyless system on camry le 2001 hippy2981 3rd & 4th Generation (1992–1996 & 1997–2001) 2 09-29-2006 02:32 PM
2002 Keyless Remote Programming garzee13 1st Generation (2000–2006) 16 04-25-2006 01:55 PM
99 LE - remote keyless entry from factory? sixto Camry & Solara Lounge 5 02-12-2006 08:51 PM
More on this damn car battery! speedemn Camry & Solara Lounge 14 01-01-2006 09:21 PM
