Turbo For Camry without the swap of a 3SGTE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2006, 02:26 AM   #1 (permalink)
Camrytogo
tropic2090's Avatar
View tropic2090's Photo Gallery
Lightbulb Turbo For Camry without the swap of a 3SGTE
Well its been awhile since I've been talking about this but well I came to a decisions I want to make my Camry a little fast since I already read the its better to swamp but I don't have does kind of resources so I had a question I found a T3 Turbo and its only oil cooled does anyone know where I can connect this line. Second at what PSI can I run it without the intercooler? And of course to not have problems with it. Thank you guys
My Ride
http://www.cardomain.com/ride/2241295
tropic2090 is offline   Reply With Quote
Old 02-20-2006, 03:39 AM   #2 (permalink)
engineer in training
Gameroom cash: $145055
Ok first off, grab a fire extinguisher something is about to get burned...
If you dont have the resources to source a used 3sgte, transmission and ecu, you are going to be hard pressed to pull together a manifold, injectors, fuel pump, tuning hardware, custom exhaust setup, and the thousand various tidbits necessary to go forced induction not to mention the downtime and the labor (there will be labor costs)... good luck!
Old 02-20-2006, 03:48 AM   #3 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
LOL Not another one.
Are you saying you want to run a T3 oil cooled turbo (wtf...??) on your standard engine, because you don't have the resources to find a used 3SGTE?? Well, you better get some contacts, because you'll be needing them when you motor blows.
JetspeedCamry is offline   Reply With Quote
Old 02-20-2006, 05:08 AM   #4 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
There is a sticky at the top for a reason.
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 02-20-2006, 11:31 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
1. Start by reading here: http://www.toyotanation.com/forum/t105924.html
2. After your done with #1, use this --> http://www.toyotanation.com/forum/search.php
3. Forget about PSI. Aim for a realistic hp goal and stick with it.
All turbos use oil. Its to lubricate the bearings and also cool. Without oil a turbo would self destruct.
Some turbos also have water cooling.
"Skoolin' the unlearned!"
Old 02-20-2006, 06:04 PM   #6 (permalink)
Pissed
View Camryamnesty's Photo Gallery
word..... PSI is your least concern now, and you need more than just a turbo, you need so much more parts, i have already spent about $600 USD on my setup, and i have not even got all the parts, and also, if you plan on going with a turbo, plan on building that motor, because as soon as you run your turbo, you are bound to run into many more problems....
Camryamnesty is offline   Reply With Quote
Old 02-20-2006, 10:31 PM   #7 (permalink)
Mad Scientist-In-Training
toyrolla's Avatar
View toyrolla's Photo Gallery
2nd Generation
May I make a suggestion which I hope you consider?
Before you do anything at this point, at least install a tranny cooler in your car.
The automatic tranny is the weakest tranny known to mankind.
It's weak for a stock 3SFE, and it's even weaker for a modified 3SFE.
So if you're already doing (or have done) headwork to your engine, your still-running automatic tranny is lucky; but can also be on borrowed time.
So if you want to keep your car running as you review your options in your quest for more HP, look out for your tranny...
...unless you got money to blow in order to fix that too.
Regards,
Toyrolla
__________________________________
88 I4 Slushie *sold*, 89 I4 5Sp *sold*, 89 V6 5Sp *sold*, 82 Corolla, 72 Datsun 510, 88 Toyota Minitruck.
toyrolla is offline   Reply With Quote
the 5sFE Turbo Upgrade Info Zrain Celica Forum 25 08-14-2007 12:31 AM
Parts needed for 3SGTE swap S2B_Blown_3.5 Camry & Solara Lounge 16 10-24-2004 07:49 PM
question on the 3sgte turbo nanno2099 Celica Forum 11 08-12-2004 02:08 PM
'94..'97 Corolla 3sgte swap mox Archived Corolla threads 3 03-10-2004 10:39 PM
