Originally Posted by BrianOwens
The Eclipse is a Head Unit
But i Dont know where the speed sensor is. Why do you need to know that for a HU?
For navigation. The speed sensor input (according to the 2002 TSRM) should be a violet wire with a white stripe. The easiest place to tap into it should be from the back of the gauge cluster.
The wire color may have changed however. For the longest time the speed wire was pink on toyotas.
You may want to invest in the more updated electrical diagram. Or call Eclipse or the place you bought it from, they may be able to help.
