well you would probabyl be better off to jsut replace the entire motor and regualtor assembly as one. IF it is stuck in the up p[osition, once you get the door panel off you should see a cable wthat runs vertical inthe door. Youcan cut that cable and it will allow the window to drop down. Once the window drops down you will see two bolts that hold the window to the actual regualtor assembly. Remove those two bolts and then you can remove the window from the door. The window comes out the top of the door. SO pull the window up and tilt it towards the front of the car slightly and you should be abel to get it out. Once you have the window out the motor assembly is bolted to the door about halfway down the door inthe middle. there should be three or four bolts that hold it in place. Remove these bolts and unplug the wire connectro from the motor. Now you can remove the entire assmebly as one piece. Reassembly is pretty much the exact opposite. If I could I would take pictures but I am not going out int he 20 degree weather and pulling my door panle off right now. If you ahve any other questions ask away. If you have a way to post pictures take some pictures and I will try to point the stuff out to you. Or you amy be able to search and find a DIY that someone else has posted.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
