Cold Start Sensor Vs. ECT Temp Sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2006, 05:53 PM   #1 (permalink)
View fourdoor's Photo Gallery
I have a 1990 Toyota Camry and in the process of doing the rear main seal, I happened to break the Cold Start Sensor-Of course-a project is never complete without breaking something! I went to Autozone to try to get a replacement and they wanted to tell me it is a temp switch, which I know it is not. But anyways they do not show a cold start injector sensor in the computer, my question will the ECT temp sensor work as they are trying to tell me it will-or is this a junkyard part/dealer part?
Thanks for any help,
Katie
fourdoor is offline   Reply With Quote
Old 02-20-2006, 06:14 PM   #2 (permalink)
Gameroom cash: $304355
There is what Toyota calls a "Cold Start Time Switch" on some of these earlier models. I don't remember when Toyota stopped using it. It was a separate sensor for telling the ECU the car is cold on initial cold start-up and it activates the cold start injector in the intack plenum. These cars also had an ECT (Engine coolant temperature sensor). The ECT should be under a green plastic electrical connector. The Cold Start Time Switch, if your car has one, will be under a brown plastic electrical connector. That should tell you and the parts guy what you are looking for. They should be right next to each other on a port coming out of the block on the driver's side. The ECT sensor runs about $40 aftermarket. The Cold Start Time Switch is only available at Toyota dealers and runs about $100. For your sake, I hope it's the ECT sensor.
Mike
Old 02-20-2006, 06:28 PM   #3 (permalink)
Mike
Its the cold start injector.....you've answered my question. To the junkyard I go.
I knew there was a reason I never listened to the AutoZone people.
Katie
SMOKE on cold start thetailwind MR2 Forum 7 11-23-2005 11:04 AM
Intake Air Temp. Sensor Check... 87_SR5 Archived Corolla threads 3 03-31-2005 06:35 PM
Cold start problem/hesitation drdma Celica Forum 3 10-03-2003 03:36 PM
price on 2 gen cold start injector? spills1969 Camry & Solara Lounge 1 07-22-2003 11:32 AM
Cold Start Switch 86CRESSIDA86 General Discussion 7 01-07-2002 10:10 PM
