Forged pistons - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2006, 12:51 PM   #1 (permalink)
View toyotacamry1's Photo Gallery
3rd Generation Forged pistons
Does anyone know of a manufacturer of forged pistons for the 5sfe that keeps the stock compression ratio? I would rather not lose power by dropping to 8.5:1. If not is there any way to raise the compression ratio higher by using a thinner headgasket?
In addition, would it be a bad idea to raise the compression from 8.5 to 9 by milling .023 off the block?
toyotacamry1 is offline   Reply With Quote
Old 02-21-2006, 02:19 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
mill the head, not the block, so much easier =)
as long as valves dont hit the pistons =)
terrastrife is offline   Reply With Quote
Old 02-21-2006, 03:28 PM   #3 (permalink)
I am am running forged for a NA/nitrous build.
And i will consider custom but it depends on how much they cost, do you have a ballpark?
Old 02-21-2006, 06:47 PM   #4 (permalink)
Gameroom cash: $368676
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
CP Pistons, Ross I think. Arias makes the rods I think
And I know you post here a lot, you know the drill. Search
RichieRichJP is offline   Reply With Quote
Old 02-22-2006, 11:30 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Stock compression ratio on a 5S-FE is 9.3:1.
Forget about milling the head/block. Buy the right pistons.
"Skoolin' the unlearned!"
Old 02-22-2006, 01:56 PM   #6 (permalink)
spin turbo hammy... SPIN!
Hamsterman's Avatar
iTrader Score: 30 reviews
View Hamsterman's Photo Gallery
YOU ARE IN LUCK!
check eBay... it is your friend, YOU CAN'T BEAT THIS PRICE! $450
new forged pistons, JE, done by el prototypes, stock compression and bore
http://cgi.ebay.com/ebaymotors/5SFE-...spagenameZWDVW
if you are serious about doing the build, shizam
Lick first... ask questions later
Hamsterman is offline   Reply With Quote
forged pistons JLcamrydave Camry & Solara Lounge 2 10-26-2005 09:11 PM
Forged Pistons? Jake25 Archived Corolla threads 12 01-17-2005 11:35 PM
forged pistons? bluedelsol Hardcore Tech and Competition 7 08-04-2003 06:50 PM
