oxygen sensor problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2006, 10:20 PM   #1 (permalink)
View mindspin's Photo Gallery
Hi all, first time post here. I have a 95 Camry LE V6 3.0L. Last Friday my check engine light came on so I had a diagnostic check at Advanced Auto Parts. The only thing that came up was the 02 sensor, so I bought a Bosch "universal" oxygen sensor, installed it, unhooked the battery for an hour or so and everything seemed well until after about 20 miles of driving it came back on. I then uninstalled the sensor, checked my wiring (everything was ok), reinstalled, unhooked battery overnight and after another 20 miles of driving the light came back on. I had a diagnostic check again and this time it says "02 Sensor Heater Circuit Malfunction" which to me could be anything. I also got a new gas cap because latley everytime I went to unscrew it at the gas pump, a lot of pressure was being released (about 5 seconds of loud hissing while unscrewing the cap). Everything else on the car seems to be ok, any suggestions? I'm not a fan of dealerships and will try to avoid taking it to a garage as much as possible. Thanks!
mindspin is offline   Reply With Quote
Old 02-21-2006, 10:35 PM   #2 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
It might sound simple, but did you wire it up correctly?
drunken_panda is offline   Reply With Quote
Old 02-21-2006, 10:50 PM   #3 (permalink)
yeah, checked it twice and had 2 different guys inspect it. 4 wires that according to the diagram match up perfectly with the OEM side of the plug.
Old 02-22-2006, 12:46 AM   #4 (permalink)
Pabloso
project92camry's Avatar
View project92camry's Photo Gallery
i heard that bosch arent that great.. u should always go OEM with senors. but anyways does ur gas tank still build up pressure.?? if it does ,u might have a problem in ur EVAP emissions system.
project92camry is offline   Reply With Quote
Old 02-22-2006, 07:35 AM   #5 (permalink)
View hooRAH's Photo Gallery
If your code is for the O2 sensor heater circuit malfunction, its not an Evap issue, so don't worry about that.
An O2 sensor only works accurately when the sensor is hot (about 600F). When the car is cold, it takes quite a while for the O2 sensor to heat up, so it has to operate without the sensor until then. Nowadays, O2 sensors have heating elements to pre-heat the sensor so the computer can use it faster.
If the system says O2 sensor heater circuit malfunction, it means that the heating element does not have the resistance between the two leads it expects (usually because the circuit is broken). In your case, you either wired it wrong, or the bosh universal sensor has a different resistance than your cars ECU is expecting.
Now, I don't mean to rag on Advance Auto parts, its cool that they read your code for free. My advice to you is that you just have them give you the code number and look it up yourself. My experience with them (and Autozone, etc), is that no matter what the code is, they tell you "its the O2 sensor" without really explaning the code. I have a feeling that you're getting the same code (heater circuit) now that you did originally, they just didn't tell you the full explanation initially. The other thing they usually don't tell you is which O2 sensor it is. Since you have a V6, you should have 3 or 4 Sensors ( I think). One on each back before the cat converter, and one (or two) after the cat converter. Do you know which sensor needs to be replaced? Do you know what the code number is? The code number will tell you which bank and sensor is giving the error.
The second thing to do, assuming that the auto parts store is referring you to the correct sensor thats giving the error, is unwire the universal sensor and do it again, trying not to remember what you did before. I know you said that two people have inspected it, but its easy to get wiring wrong and have it look right. Heck, the wire leads for the O2 sensor might even be labeled wrong. If that doesn't work, then you might have to try an OEM sensor.
That may sound like a lot of work, but worst case scenario is that you have to buy an OEM sensor and put it in. You'll stay away from the mechanic shop at least, and thats something, right?
Hope this helps.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
Old 02-22-2006, 10:20 PM   #6 (permalink)
Thanks for the reply, great info. The first time I had it checked, the code literally said "02 sensor upstream ... " cant remember the rest but the guy said it would show each sensor that was bad and that only the upstream (one that's up front and easy to access) was bad this time. The car just hit 120k so I figured it was time anyway to replace the sesnor, but the reason I went for the bosch was the OEM was $168 (thanks toyota... ) and I think that store was out of them that day. It was after I installed the bosch (twice because I rewired) the diagnostic then gave the heater malfunction which to me shows I wired it wrong but it's right, I swear by it. BTW it's an Actron diagnostic reader is what this particular store uses, I may try a differnet store and get the actual codes and research myself as you suggested. I'll keep this post updated incase anyone else runs in to this issue. Thanks again.
2000 Solara check engine light mytoyota02 Solara 25 10-16-2011 12:06 PM
1993 Toyota Pick-up Oxygen Sensor Wiring Shawn1977 89-95 Toyota Pickup/Hilux 3 05-11-2011 10:10 AM
Replacing Oxygen Sensor For corolla 98 1998corolla1998 Archived Corolla threads 13 07-05-2010 11:35 AM
Use apexi safcII to monitor oxygen sensor klone1000 Celica Forum 1 01-04-2006 08:08 PM
oxygen sensor, help! mjoe Camry & Solara Lounge 5 04-06-2005 08:34 PM
