Spray Paint - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2006, 12:35 AM   #1 (permalink)
View Gull's Photo Gallery
XXX Spray Paint
I was wondering if it would be a good idea to spray paint the inside of my car like the door handles, air vents, just the little stuff on the dash, etc...
Or should I just buy the pieces.
And if so how much would the pieces cost on a '98
Gull is offline   Reply With Quote
Old 02-22-2006, 12:38 AM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397185
View RningOnFumes's Photo Gallery
i 've seen decent work on spray paint stuff...but you need patience to make it come out right
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is online now   Reply With Quote
Old 02-22-2006, 12:42 AM   #3 (permalink)
I see, well that shouldn't be a problem, and what kind of paint would you recommend?
Old 02-22-2006, 12:43 AM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
car paint :P
the touch up stuff in a can.
one coat will last forever. doesnt scrach (unless you run a nail onit) and doesnt come off from abuse...
BUT
costs about 2x more then hobby paint and 5x more then cheap canned paint.
terrastrife is offline   Reply With Quote
Old 02-22-2006, 12:44 AM   #5 (permalink)
Ninja-rator
for that my friend, others need to chime in, i haven't tried it myself
Old 02-22-2006, 12:47 AM   #6 (permalink)
Sorry if this sounds kinda stupid, im new at this, but by car paint do you mean the shit you put on the outside of your car??? or is there a special spray paint thingy that goes specifically for the inside.
Originally Posted by terrastrife
car paint :P
BUT
Old 02-22-2006, 02:36 AM   #7 (permalink)
Australian TN'er
View Phat Devil's Photo Gallery
There is only 1 thing you have to think carefully about
Paint has a thickness. Some of your trim bits are TIGHTLY pushed into place <-- air vents. This will definitely cause a problem if your paint is too thick. And i wouldnt put it on the door handle as they are touched everytime you open the door. Unless you are willing to touch it up every so often, i'd skip that bit. Or put it on thicker but that causes the problem i said above =P
Phat Devil is offline   Reply With Quote
Old 02-22-2006, 02:39 AM   #8 (permalink)
yeah i mean exterior car touch up paint, in a spray can.
that shit lasts forever. i used it to paint my cd rom drives, one thin coat and theres no signs of scratches or fading on the eject button at all after 2-3 years =)
the paints designed for abuse =)
Old 02-22-2006, 11:46 PM   #9 (permalink)
aka DA PROBLEM!
KILRCAM's Avatar
View KILRCAM's Photo Gallery
Use the SEMA interior paint. All the interior shops use it and I used it on my old 92. It worked great. Just take your time.
KILRCAM is offline   Reply With Quote
Old 02-23-2006, 12:15 AM   #10 (permalink)
View cmdrkettch's Photo Gallery
Or perhaps you can consider vinyl dye. I haven't used it myself so I can't give much info, but I've heard of its application in the computer modding scene.
cmdrkettch is offline   Reply With Quote
Old 02-23-2006, 08:43 PM   #11 (permalink)
vinyl dye is paint. works too but if you dont let it cure before you start using it (leave it in the sun for a couple of days) its gonna be messy.
Old 02-23-2006, 11:43 PM   #12 (permalink)
View toyotacamry1's Photo Gallery
Strangley enough i had the same problem but have recently solved it. I purchased a air brush and small electric compressor at my local ace hardware and picked up some of the stuff my friend recomended. This stuff is great and apparently won't chip off or anything. He even has it on his door handles and i could have sworn it was stock. It is sold by the quart through parasol Inc. online. I beleive they also have a vinly dye i will be trying on my dash. I have a tan interior that i am changing to black so i will let you know how it works.
toyotacamry1 is offline   Reply With Quote
Old 02-24-2006, 12:14 AM   #13 (permalink)
yeah its good becasue it seeps in a millimeter or 2 so even if you do scratch the part its still the same color underneath
Old 02-24-2006, 04:17 PM   #14 (permalink)
cdncamry's Avatar
View cdncamry's Photo Gallery
I painted several pieces of trim on my civic with a can of ford silver touch-up. The results are good, no chipping at all after 4 years. I put down a coat of non-metal surface primer for good adhesion before I applied the paint. I would like to do the same for my Cam, but I dunno what color would look good with a beige interior?
2001 Civic Lx, I/H/E - 15.72 @ 88.5MPH
2000 Camry CE 2.2 Auto - 19.6 MPG
cdncamry is offline   Reply With Quote
Painting Car With Spray Paint 90celica General Discussion 26 05-13-2009 07:45 AM
I'm new and I bring Tips on how to paint! TriumphGT6 General Discussion 11 02-15-2007 04:17 PM
96 camry dk. green with spray paint?!?!?! desertstrm2000 3rd & 4th Generation (1992–1996 & 1997–2001) 6 05-04-2005 12:41 AM
new to the board, question about paint / spray paint BillJohnson Camry & Solara Lounge 10 10-02-2004 03:44 AM
