How to change DIFF fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2006, 03:11 PM   #1 (permalink)
View Gnfanatic's Photo Gallery
hey Guys I appreicate the help. I got a 1999 Toy 4 cyl camry. I replaced the trans fluid and filter which worked out great. I would like to replace the diff fluid to but not sure how and what fluid to use. I saw a plug in back of diff but it is to hi for a drain plug. Maybe thats the FILL plug and there is a drain plug I didnt see??
thanks
Ralph
Gnfanatic is offline   Reply With Quote
Old 02-22-2006, 03:29 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Use Dexron II/III ATF.
"Skoolin' the unlearned!"
Old 02-22-2006, 03:32 PM   #3 (permalink)
Thanks man! great PIC!Are you pos I am suppose to put atf in the diff??? doesnt sound right.
thanks
Ralph
Old 02-22-2006, 03:34 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
^ Yes, I'm positive that the diff uses ATF.
Don't believe me? Drain the diff and see for yourself.
Old 02-22-2006, 03:37 PM   #5 (permalink)
and no additvies? sound sgreat. going to do it tomorrow. I feel a funny clunky feel when turning the car hard while pulling out of parking lot. I am hoping the fluoid is low or something. the cv joints boots looked good..
Thanks
Ralph
Old 02-22-2006, 03:46 PM   #6 (permalink)
Gameroom cash: $304355
Just a bit of advice. Don't remove the diff drain plug until you first remove the filler plug. Then, if you can't get the fill off you are not stuck.
Mike
Old 02-22-2006, 04:04 PM   #7 (permalink)
excellent advice Mike.
guys, one more`question. how much do I put in?
thanks
Old 02-22-2006, 07:03 PM   #8 (permalink)
View fe519's Photo Gallery
i got a 98 V6... sounds stupid but, it took me a LONG time to fill it because there was just no room. I tried a funnel, funnel with a tube, etc etc. What is your trick?
fe519 is offline   Reply With Quote
Old 02-22-2006, 07:12 PM   #9 (permalink)
I would think you warm up the atf bottle with hot water so the atf is thinner. Then use a long a$$ tube and do it that way. might have to pop a breather hole in the bottle.. How do you know how much to put in though???
thanks
Old 02-22-2006, 07:43 PM   #10 (permalink)
Grenaded piston
88 LE's Avatar
^ Your tranny takes around 1 1/2 quarts.
You'll know when its full. Fluid will drip out of the fill hole or backup into the tube, if your using a tube.
I use a funnel with a long clear tube.
Make sure the car is level when you fill the diff, otherwise it won't fill up correctly.
Old 02-23-2006, 09:14 AM   #11 (permalink)
View noodlerooney's Photo Gallery
I like to use the Mobil1 synthetic Dexron III ATF in the differential since it's a closed system.
00 Solara SLE V6 1MZ-FE, 16.5K miles "Garage Queen"
94 Camry LE I4 5S-FE
noodlerooney is offline   Reply With Quote
Trans/diff fluid question - '96 LE 2.2L w/A140E Truthunter 3rd & 4th Generation (1992–1996 & 1997–2001) 11 12-05-2007 01:22 PM
Transmission fluid change intervials? 92camryguy04 Camry & Solara Lounge 16 02-05-2005 10:19 AM
need to change p/s fluid, how to?? hct73 Celica Forum 5 12-25-2004 09:17 PM
85 Tercel 4x4 needs front diff change info willc733 Tercel, Paseo, Starlet, and Sera Forum 0 09-07-2004 08:48 PM
Ford brake conspiracy EKam Hardcore Tech and Competition 19 04-02-2004 07:17 PM
