Brake's DUE, What brake pads and rotors? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2006, 04:41 PM   #1 (permalink)
pcboy123's Avatar
View pcboy123's Photo Gallery
Gen5 Brake's DUE, What brake pads and rotors?
Hello,
Well I have a 04 Camry V6 3.3 and the brakes are due,( I drive alot in 1yr i put 30k miles)
Im thinking of putting slotted/drilled rotors, just dont know if thats a good move or not, so i wanna know if any one has changed there's and to what brand..
Also the brakes, for front and rear , what brand you used..
i might go TRD for the brakes but not sure.. kind of pricy..
Currently Have
04' Camry SE V6
With Factory Bodykit
pcboy123 is offline   Reply With Quote
Old 02-22-2006, 06:19 PM   #2 (permalink)
View majorgercko1's Photo Gallery
Thats my next mod i plan to do. (after my 20s) I was looking around and thought about getting a big brake kit. It would be much better but more expenive. Anyways, i if i was going for the rotors only, there is a guy in ebay selling a set of 4 for like 100 bucks or something, look around.
I dare you to compare...
majorgercko1 is offline   Reply With Quote
Old 02-22-2006, 06:23 PM   #3 (permalink)
pcboy123's Avatar
What kind of 20"s
whats your off set?
i want to do it to but first brakes and rotors before rims..
i heard you can only do 19's
5 lug of 7.5 inch wide. or they will rub..
what do u think?
Currently Have
04' Camry SE V6
Old 02-22-2006, 06:31 PM   #4 (permalink)
pcboy123's Avatar
well i found this guy! for my rotors,, and he's local =)
ebay link!
http://cgi.ebay.com/ebaymotors/Toyot...spagenameZWDVW
Currently Have
04' Camry SE V6
Old 02-22-2006, 06:35 PM   #5 (permalink)
here are some links for the rotors, you can chose from these:
http://cgi.ebay.com/ebaymotors/Perfo...11592617QQrdZ1
http://cgi.ebay.com/ebaymotors/SR-Ro...spagenameZWDVW
regarding the size, lsmaller rims= better ride quality, well, i mean you dont need to worry about bumps or holes, wheas i will need to.
Naw you can go more than 20, i tried on 20 inch rims at some shop with my car lowered hows that? Imagine if it wasent? i could put in like 22s. But the tire was thin, i am going to buy em from a friend i am getting a good deal, 1 gran for 20s with brand new tired chrome 5 spoke, 3 inch lip, and trust me the way they are designed they will fit. I know many of you will tell me no way, but oh well. Hes a pic i took of em with my cell.
Where he bought them they told him he can oder to paint them any color for free. He paid like 3 gran or something for em. I was thinking about painting them blue like my car but it would be too much =D
Old 02-22-2006, 06:36 PM   #6 (permalink)
ebay link!
Dont forget about the little details in your car. Such as if it is v6 or i4 and model xle se le etc.. Le and se are not the same, so check those links that i gave u and they will tell you that.
Old 02-22-2006, 07:57 PM   #7 (permalink)
Import Fire Fighter
View theMANry's Photo Gallery
im running napa rotors and pads, they work great for me. i got rotors ceramic pads for the front for 105 bux
2008 Scion xB 5spd
AEM CAI - TRD Exhaust w/o Second cat -
-TRD 19's - Eibach Sportlines -
many other goodies
theMANry is offline   Reply With Quote
Old 02-22-2006, 09:27 PM   #8 (permalink)
View 02CamryLEV6's Photo Gallery
I have an 02 Camry LE V6 with the original brake pads and rotors with 90k on them, does Toyota use ceramic brakes on the V6? I want to replace with them the original equipment since they lasted me so long. What does a Toyota dealership approx charge to replace the pads for the front and rear?
02CamryLEV6 is offline   Reply With Quote
Old 02-22-2006, 09:35 PM   #9 (permalink)
06 Camry LE I4
View y_one2000's Photo Gallery
Hi, I have a 06 Camry LE. Can I change the rear drum break to disk break?
Is it a lot of work?
thn
y_one2000 is offline   Reply With Quote
Old 02-22-2006, 09:53 PM   #10 (permalink)
macr88's Avatar
View macr88's Photo Gallery
4th Generation
You probably won't have to touch the rears.
I've heard really good things about the NAPA rotors.
Don't waste your money on TRD pads.
I was using Performance Friction pads on the front and they were great but dusted quite a bit but I don't mind that. Lifetime waranty at Pepboys.
I have the Stoptech big brake kit on my car now and nothing I've tried compares to these. Using AXXIS pads with these rotors.
If you drive hard stay away from drilled rotors. Slotted? not sure. I tried the Powerslot rotorsbut they didn't last. The Brembo solid rotors were the best stock rotors.
macr88 is offline   Reply With Quote
Old 02-22-2006, 11:39 PM   #11 (permalink)
thn
It think its an expensive transformation. I am not sure but i think there are many things you would need to do.
Old 02-23-2006, 01:02 AM   #12 (permalink)
pcboy123's Avatar
4th Generation
so what about the rims
who has 19+ inch rims on there camry with the width of the rim wider than 7.5in'
Currently Have
04' Camry SE V6
Old 02-23-2006, 11:14 AM   #13 (permalink)
pcboy123's Avatar
SO this is what i found out so far about the rims for my 04 camry SE
Bolt Pattern: 5x114.3 (5x4.5)
Offset Range: 38 to 45
Wheel Size Range: 16x6.0 to 20x8.5
OEM Tire Size (Front): 215/60-16 (215x664 mm)
Max Tire Dimensions: 245x680.0
Currently Have
04' Camry SE V6
Old 02-23-2006, 11:59 AM   #14 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
thn
Price to performance ratio = not worth it.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 02-23-2006, 12:12 PM   #15 (permalink)
HID/Retrofit Expert
You're all wrong. I saw a Gen 5 with 21's.
Gen4 brake rotors and pads replacement Luc Hardcore Tech and Competition 5 03-06-2012 03:40 PM
Are these good rotors to get? cman2000 Camry & Solara Lounge 32 11-24-2007 01:32 AM
Suspension, Brake Pads, Rotors, and Exhaust All Shot - Need Advice TradeViceroy Camry & Solara Lounge 6 10-26-2005 03:06 AM
Should I do this or just change the pads? abimanyu Archived Corolla threads 2 09-27-2005 07:48 AM
Good discussion on x-drilled/slotted brakes EKam Hardcore Tech and Competition 44 12-29-2003 11:46 AM
