The problem with using aftermarket struts are not the struts themselves, it is still the strut mounts. Apparently, Toyota redesigned them for the early Gen4 era and didn't inform anyone. So companies like Bilstein, Tokico, etc. never accommodated the updated mounts, as they probably wouldn't spend more time and money to change a bit. So TRD had developed an isolator kit, which was basically just a thick rubber gasket, to fit inside the strut mounts. However, this kit has been discontinued, and the few that were lucky to get them had no more noises. Sometimes, tightening down the center strut nut will help a bit, but eventually it's not a long-term solution.
Luc
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
