thanks alot. In that case I have no idea why I am only getting 18mpg. I replaced the sensor before the cat, changed the plugs, cap and rotor, fuel filter, air filter and thermostat. I check the ECT sensor and it is in spec. My consistent mpg is 18. I get more on my 91 300zx!! Does anyone have any other suggestions. I checked that the wheels turn easily and they do so there is no brake binding or anything like this. I have also changed the oil recently. Not sure if that would affect mileage. Tires are all filled to proper psi, ECT switch on transmissin is UP (off) and I do not drive it hard. So a heavy foot is not the problem. I checked the resistance on the ignition wires as well and they are also in spec. The CEL is not on. I am lost at this point.
