Timing Belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2006, 05:54 PM   #1 (permalink)
View souellette's Photo Gallery
Timing Belt
I Have an '84 Camry with the 2S-E engine. The timing belt broke. Is this an interference engine? Am I sending this car to the scrap yard?
souellette is offline   Reply With Quote
Old 02-23-2006, 05:58 PM   #2 (permalink)
Gameroom cash: $926800
iTrader Score: 13 reviews
View ASG14's Photo Gallery
I Think it should be fine. I know the later engines in the Camry's (such as the 3S-FE continuation of yours) is fine if the belt is just replaced. Hopefully someone here has more concrete knowledge of your engine though.
5 Lug Corolla WHAT?
Old 02-23-2006, 06:00 PM   #3 (permalink)
Any particular reason it's draining water as well? possible water pump damage at the same time?
Old 02-23-2006, 06:01 PM   #4 (permalink)
I haven't quite traced the source of the leak
Old 02-24-2006, 01:02 AM   #5 (permalink)
Maybe the water pump broke, CAUSING the timing belt to break, or not be on?
5 Lug Corolla WHAT?
Old 05-14-2006, 03:39 PM   #6 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Thumbs up
Souellette,
I broke a timing belt on my old '85 Camry years ago. My car had the same engine yours does. I can definitely tell you that that engine is a non-interference one.
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Old 05-15-2006, 10:36 AM   #7 (permalink)
View marc780's Photo Gallery
ASG is probably right on the scenario. Because maybe the water pump pulley seized up and this snapped the belt. Or a leaky water pump soaked the belt, and made it slip, overheat and break.
Either way you can find out if this is an interference engine or not, just call toyota dealer or look it up. I dont believe it isan interference engine. So all you are looking at, with any luck, is a new water pump and timing belt and maybe the idlers. Less that $200 if you can do it yourself.
Old 05-16-2006, 11:26 PM   #8 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
put a pump and belt on it
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 09:06 AM
Timing belt tension spring's purpose AFTER belt install? awmccready Camry & Solara Lounge 4 09-20-2009 02:59 AM
timing belt replaced, now 5 deg atdc?? asm Camry & Solara Lounge 5 07-20-2005 04:22 AM
Timing Belt work mandyfig Camry & Solara Lounge 1 02-07-2005 08:35 AM
