one headlamp brighter than the other - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2006, 09:04 PM   #1 (permalink)
Toyota Fan
View Todd Soden's Photo Gallery
4th Generation one headlamp brighter than the other
I noticed on my 2000 gen 4.5 that the divers headlamp is brighter than the passengers. Upon closer inspection i noticed that the small reflective cover that goes overtop of the low beam light bulb is no longer silver but more like a burnt brown colour. Is there an easy way to replace or remove this piece? I am not sure why it got this way, but suspect it had to do with a high heat (higher than normal).
2000 Camry CE
2000 Echo
Todd Soden is offline   Reply With Quote
Old 02-23-2006, 09:53 PM   #2 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
If it really bothers you, just buy a headlight off of ebay (or 2 of the crystal clear ones) I don't think there IS a good way to fix it, unless you can take the reflector part out.
BlueFusion6851 is offline   Reply With Quote
Old 02-23-2006, 10:00 PM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
the only way would be to take the lense off your headlight, and then see if it's just a burnt film on top, or if the reflective plastic itself is burnt
if you really don't want to buy a new headlight, and you've taken it apart, you can try using tin foil/aluminum foil to line the inside of the cap to make it reflective again
HaHa
Old 02-23-2006, 10:50 PM   #4 (permalink)
NTL
View NTL's Photo Gallery
My reflective covers that go over the lowbeams is the same way you described it. It has a slight burnt brown color to it. I'm running modded 9005 silverstars in my lowbeams and thought the extra wattage/heat was causing it. Are you on stock bulbs?
2001 Toyota Camry LE V6 Gallery Edition
NTL is offline   Reply With Quote
Old 02-24-2006, 09:29 AM   #5 (permalink)
Gen 4 Snow Lover
View randomman84's Photo Gallery
i have the same set up as above and mine look that way too. I wonder if it is the extra heat from the higher wattage bulbs? My silverstars are blowing way too fast too. Do you have that problem?
Gen 4 to Gen 4.5 FEC (Front End Conversion) Complete!!!!! Pics Below!!
Official DIY (Kinda)
http://toyotanation.com/forum/showth...389#post856389
randomman84 is offline   Reply With Quote
Old 02-24-2006, 01:48 PM   #6 (permalink)
Gameroom cash: $304355
It is definitely the heat from the higher wattage bulbs. I have a friend who is a professional Mazda tech and he has seen numerous cars come in with non-standard bulbs that are melting the headlight housings, some on relatively new cars. He says Mazda won't replace these items under warranty. It's a customer pay item, since a non-recommended part was used and caused the problem.
Mike
OFFICIAL Gen. 3 Clear Headlamp DIY Thread thisdj78 Camry & Solara Lounge 132 11-07-2010 12:02 PM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
Headlamp assembly andylogan General Discussion 2 01-21-2005 09:20 AM
brighter headlights... fe519 Camry & Solara Lounge 25 11-02-2003 08:55 PM
why no projector headlamp for Camry? Tubbyc Camry & Solara Lounge 37 12-17-2002 01:41 PM
