5S-FE 5-speed conversion, need a couple bits of info - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2006, 09:24 PM   #1 (permalink)
View Spule 4's Photo Gallery
3rd Generation 5S-FE 5-speed conversion, need a couple bits of info
All:
I have a 1992 LE 5S-FE Camry Wagon here that I am considering doing a five speed conversion on since the (blown) motor is coming out and the autobox is just shy of a quarter million miles.
I have read over the info in the Camry FAQ section and others online, but all I can find are persons that did the conversions on V6 cars.
Most of the conversion is covered elsewhere, but here are the bits I wish to figure out, if someone has answers or can direct me to them, I would appreciate the help:
Transmission code: E153, was this box used on all Gen 3 cars? From a Toyota of Germany tech sheet I have it shows the European market Gen 3 V6 and I4 cars having the same ratios, ditto in the States?
It appears with the 5S-FE the axels are the same on automatic/5 speed unlike the six?
What tricks/problems with the ECU for 1992 for the 5S-FE (other than neutral safety switch)?
Any other advice would be of help. I have done a few import automatic to manual conversions in the past, a bit of work, but worth it in the end.
Thanks and until later -
Garrett
Spule 4 is offline   Reply With Quote
Old 02-23-2006, 09:48 PM   #2 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
Find a junked Camry. Pull the gauges, the ecu, the clutch assy, reservoir, etc etc etc etc. I would personally just buy a Manual transmission'd Camry out of the box. (1993 V6 SE )
BlueFusion6851 is offline   Reply With Quote
Old 02-23-2006, 10:44 PM   #3 (permalink)
Well, there lies the rub...
I have a junked Camry here, 1995 5S-FE LE 7-passenger wagon (anyone need a nice tan interior?). This is the source of my motor, 134a air-con, rear disc brakes and suspension. I can find the bits I need from local junkyards/Toyota, but have yet to find an entire dead 5-speed car. Unfortunately, this one is going to be piecemeal at best....
I converted a Volvo once (my first conversion) and had both cars to work from, which was nice to see how things were arranged. My last conversion was a Renault R21/Medallion and I did not have both cars and it was a bit more difficult.
Thanks-
Garrett
Old 03-01-2006, 07:54 PM   #4 (permalink)
All:
I have the motor out of both cars (one you can see daylight though one where the big end of rod #4 decided to leave out both sides of the block) and the other is on the stand ready to have parts swapped over. I have my 134a and rear disc brake parts to pull yet too off the black car.
Soon it will be time to gather the transmission bits, so any help I could get soon would be most appreciated.
Or am I going into new territory, as I said before, all the info I could find was for the V6s.
One other bit, the hydraulic motor mounts on both of my cars have A/T marked on their boots. Am I to assume that the auto and manual mouts are different dampening between the cars (I have seen this on other cars). Anyone else have a comment on this, or is the AT not transmission related?
Thanks again!
Garrett
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
5 speed conversion turbo_Runner 4Runner Lounge 0 10-10-2005 03:24 AM
Tire suggestions? Vaipunk Archived Corolla threads 11 03-11-2005 06:48 AM
5 speed conversion? Beaver Camry & Solara Lounge 12 02-08-2005 01:19 AM
Standard To Manual 6 Speed Conversion vtsuckah Supra Forum 9 10-01-2004 07:34 AM
