that info is wrong.
if you actaully bother to LOOK at the butteryfly. and if you actually read what ACIS means.
if your vacuum hose is collapsing (under vacuum) then you will loose power as the butterfly re opens when its supposed to be closed. <-- this is the main reason/problem that most ppl get.
i know what im on about. the haynes manual doesnt know wtf its on about. sure, its theory is right, but in practice the vsv switches the actuator TOO LATE. the butterfly should be closing at around 2000rpm for the engine to use the shorter intake runner length. this is the reason you see the drop of power between the 2000rpm peak and the 4000rpm peak... in dyno charts...that SHOULDNT BE THERE, and it IS NOT there with the the switching done earlier, or permanently.
heres what i was looking for
see torque dip? all gone with acis closed.
another bit to explain, the torque flatness before 2600rpm is due to the stall not being locked yet as well, im pretty sure. thats why as soon as the auto locks the torque jumps to what it should be.... which is why auto 3vzfe's suck =)
