oil leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-24-2006, 04:08 PM   #1 (permalink)
Art In Motion
Mayne Event's Avatar
View Mayne Event's Photo Gallery
oil leak
Alright, so I had my clutch replaced at a shop so it was someone who knew what they were doing BUT ever since I had it replaced my car has been leaking about 1 quart of oil between oil changes. It stinks, it is ruining my garage floor AND obviously not good on my engine. Is there a gasket that got put in wrong or one that should have been replaced? My car didnt leak any oil before this and I want it to stop. Any tips? BTW Its a 95 camry coupe 5 speed manual tranny.
There are no stupid questions, Just stupid people.
http://www.cardomain.com/id/badblood
Mayne Event is offline   Reply With Quote
Old 02-24-2006, 04:28 PM   #2 (permalink)
Art In Motion
also if theres anything I could add to help stop oil leaks all together instead of a gasket like some additive
Old 02-24-2006, 04:31 PM   #3 (permalink)
cdncamry's Avatar
View cdncamry's Photo Gallery
Have you been under the car to see where the leak is coming from?
The only quick-fix I can suggest would be to try to clean both mating surfaces as well as you can with some brake cleaner, and then seal the gap with a thick bead of silicone.
2001 Civic Lx, I/H/E - 15.72 @ 88.5MPH
2000 Camry CE 2.2 Auto - 19.6 MPG
cdncamry is offline   Reply With Quote
Old 02-24-2006, 04:40 PM   #4 (permalink)
View Gary_602Z's Photo Gallery
Sealing the mating surfaces between the tranny and engine will not help! It is either a rear main seal in which case the tranny will have to come out again, or an external leak someplace on the engine. You have to find out first before you jump to conclusions. No additives will help.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 02-24-2006, 04:51 PM   #5 (permalink)
Art In Motion
thanx for the input gary. bassed off what u said, unless they messed with something else the only option really is the rear main seal. The car dident leak a drop of oil BEFORE the tranny was seperated from the engine so its gotta be the rear main seal. I will still get under there and clean it up and check it out, thnx.
Old 02-24-2006, 05:01 PM   #6 (permalink)
Just make sure it is not leaking from above and dripping down. If it is a rear main seal it should be dripping between the engine and tranny. Did they replace the rear main seal when they did the clutch? If not they should have as it is simple and cheap to do while they are there.
Gary
Old 02-24-2006, 05:09 PM   #7 (permalink)
Art In Motion
so I just spoke with the mech who did the tranny job and they said if it wasnt leaking before they wont replace it, actually let me rephrase that "if it aint broke, dont fix it" in other words they DIDNT replace the seal and ima have to find someone to drop the tranny out and do it since I have a lack there of when it comes to proper equipment OR take it to a shop and pay someone 300$ to do it. Bastards.........
oil leak! help! matrix37495 Tercel, Paseo, Starlet, and Sera Forum 7 05-28-2005 10:49 PM
Oil leak problem Robbo Supra Forum 5 05-23-2005 06:48 AM
Oil Leak possibilities jsandek Camry & Solara Lounge 7 02-28-2005 01:29 PM
Me and my oil leak -- help! jawhie Celica Forum 11 01-10-2005 09:51 AM
Massive Oil Leak..possibly front main seal EMMETT03 Camry & Solara Lounge 4 12-06-2004 08:46 PM
