Auto to Manual Swap shifter options? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-26-2006, 09:01 PM   #1 (permalink)
Blazyntoyo
View 90camdx4's Photo Gallery
Question Auto to Manual Swap shifter options?
I have a gen 2 and i know that a shifter from a manual gen 2 camry would work for the swap..but would a shifter from any of the following work 89 celica alltrac or 91 celica gts?
90camdx4 is offline   Reply With Quote
Old 02-27-2006, 07:27 AM   #2 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
i use a 91 celica shifter base in my gen 3 camry... it should work for you. the holes may not line up, mine dont, but you may have better luck with a gen 2... but you can always make something work if it doesnt bolt right up. the cable length and everything else will be fine though.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 02-27-2006, 02:30 PM   #3 (permalink)
Blazyntoyo
thanks for the info zoni...i may just go with the celica shifter then.
Old 02-27-2006, 06:03 PM   #4 (permalink)
I'm a Mac
zoni's Avatar
like i said, it most likely wont fit perfectly, but it will work. the only thing was that the throws were a little different... the actual post angles back far towards the rear. the camry one is more in the center.
Dave Zoni
Swap a 3 speed auto to a 4 speed auto? jijiandfarmgang Tercel, Paseo, Starlet, and Sera Forum 2 08-12-2005 07:23 PM
Swap Options for an AE91? SpeedballTrix Archived Corolla threads 12 08-07-2005 10:52 PM
modded my ES250 manual shifter lexusmech General Lexus Discussion 0 07-14-2004 10:11 AM
which manual tranny should use for 5thgen swap? asianchen Celica Forum 6 06-27-2003 06:15 AM
Manual vs. Auto OU8MYDUST Camry & Solara Lounge 7 08-13-2002 09:59 AM
