Made a diagnosis of my engine... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2006, 03:49 AM   #1 (permalink)
View Camry-rulez's Photo Gallery
Hi
Yeasterday i have made a diagnosis of my engine. I've put a jumper wire and connected the terminals TE1 and E1 of the DLC 1 (Data Link Connector) then I turned the Key on "ON". Then the MIL (CHECK ENGINE) has begun to flash. (It flashed 1_1111) = code 14. What dose this code mean? (Is it something whit the Ignition?) please Help me.... (the engine is runing good but I think that the engine is not so powerfull that it was for example 1 year ago.... HELP
Euro CAMRY. 3.0 GX V6 (auto.) 1993'
Toyota Camry and Peugeot 205 Driver
Camry-rulez is offline   Reply With Quote
Old 02-27-2006, 11:47 AM   #2 (permalink)
do someone know??
Old 02-27-2006, 12:14 PM   #3 (permalink)
View thisisntjoew's Photo Gallery
I believe it is "no spark" (code 14). I will look it up by tomorrow and repost if I am wrong.
thisisntjoew is offline   Reply With Quote
Old 02-27-2006, 04:13 PM   #4 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
Haynes Manual says...(System) Ignition signal,(Diagnosis) no "IGF" signal to the ECM 8 times in succession, (Trouble Area) Igniter circut, igniter ECM
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 02-27-2006, 04:20 PM   #5 (permalink)
than it could be something whit the sparks etc...?
Old 03-04-2006, 04:56 PM   #6 (permalink)
Rockin the T100
View slammin211s's Photo Gallery
hey guys i just registered.
My friend has a 94 camry xle v6. Check engine light just came on
where is the connector i need to jumper to pull the code?
and where can i find a list of the codes
please help i have been googling for like 1/2 hr and found nothing.
slammin211s is offline   Reply With Quote
Old 03-04-2006, 05:12 PM   #7 (permalink)
the connector is under on the left side of the engine (a little black box) but you have a 1MZ-FE engine? than you have a OBD II connector under the steeringweel, next to the fusebox. But if the 1MZ-FE engine has a DLC tan you must connect the terminals TE1 and E1... I have the list on my PC if you want...
Old 03-04-2006, 05:17 PM   #8 (permalink)
http://personal.utulsa.edu/~nathan-b...85diagnosi.pdf
this can help you! ^^^ there is the description of the diagnosis System of a 3VZ-E engine... but the system is the same like in a 3VZ-FE (and 1MZ-FE- I think so)... there is alsow the list of the Diadnostic Trouble Codes....
Old 03-05-2006, 01:59 AM   #9 (permalink)
Pabloso
project92camry's Avatar
View project92camry's Photo Gallery
http://www.toyotanation.com/forum/t99930.html
MAYBE THIS WILL HELP ^^^
project92camry is offline   Reply With Quote
Old 03-05-2006, 12:13 PM   #10 (permalink)
Gen 3
View rdimpulser6's Photo Gallery
You can download the repair manual. It's a sticky on the front page of the camry forum. It's under EG2 page 400. This is for OBD II. IT will show you where everything is located.
rdimpulser6 is offline   Reply With Quote
Old 03-05-2006, 03:22 PM   #11 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You can't jumper anything on that car to pull the codes.
All 1MZ-FEs are OBD-II, so you need a scanner to pull the codes.
"Skoolin' the unlearned!"
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Can I use Synthetic motor Oil at 5k miles? Meteor_Proof 2nd Generation (2005+) 39 04-07-2006 01:00 PM
Turbochargers Xenon Hardcore Tech and Competition 13 01-04-2004 08:12 PM
