Cigarette Light Ring change. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2006, 10:47 PM   #1 (permalink)
View Grayguy's Photo Gallery
I searched and found a brief comment from CrawlingEye about it, but I can't figure it out. How do i do this swap?
Originally Posted by CrawlingEye
That's pretty simple. It's just a 74 bulb/LED. You just pull the U bent piece from around the stereo and look at the back of the cigarette lighter (there's a black cover) and the base just twists into there.
But judging by what I have it doesn't make sense...
Grayguy is offline   Reply With Quote
Old 02-27-2006, 10:50 PM   #2 (permalink)
TN's Nikon Expert?
prnc_chrmng's Avatar
Gameroom cash: $491868
View prnc_chrmng's Photo Gallery
you cant just pull that sucker out and swap them?
Originally Posted by 98tercel_girlie
This thread needs more porn, less blah blah
prnc_chrmng is offline   Reply With Quote
Old 02-27-2006, 10:51 PM   #3 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
Other than the fact that your new LED bulb is long, I'm not seeing what doesn't make any sense here.
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 02-27-2006, 11:17 PM   #4 (permalink)
I can't get that light outta that socket for anything. I turned, I pulled, I pried...
Old 02-27-2006, 11:42 PM   #5 (permalink)
bitch please
DarkMastyr's Avatar
I believe it's soldered in, just like the 194 bulbs in your speedo.
Old 02-28-2006, 12:00 AM   #6 (permalink)
there weren't any bulbs soldered in im the gauges. I just had to pull out the sockets and plug in the new bulbs...
so what, should i just break it or soemthing?
Old 02-28-2006, 12:13 AM   #7 (permalink)
bitch please
DarkMastyr's Avatar
-shrugs- depends on the car I guess. Some of us had our bulbs soldered into the holders of our gauges, so I figure it's the same here. Might as well break it and use a pair of needle nosed pliers to clean it up if you can't figure it out. I just painted mine with glass paint. Didn't exactly work all that well since the bulb was so small. Worked well for the 194 bulbs though.
Old 02-28-2006, 12:27 AM   #8 (permalink)
well thanks for the advice, I guess I'll just play with it more tommorow
Old 02-28-2006, 12:45 AM   #9 (permalink)
View AmanO's Photo Gallery
I did this conversion.
It is a ghetto solution but it worked. Take that apart as much as possible. You can get the bulb out somehow, I forgot. Then desolder the contact points that are attached to the bulb.
Then bend the wires on the LED and solder the contact points back on. Shave as much off the front of the LED as you can.
Then when you try to put it back together, you can get the light back in the socket, but not far enough to twist and lock it. I just taped it so it wont come out.
Now I remember. You push down on teh bulb ot get it out. Push down on metal nubs also.
4.0 Gen XLE V6. Minor light mods. No money for supercharger.
Driver side mirror got owned by a Taco Bell
AmanO is offline   Reply With Quote
Stuck - removing RH driveaxle from bearing mount awmccready Camry & Solara Lounge 12 04-16-2011 06:53 PM
piaa vs stock ProjectCorolla Archived Corolla threads 37 02-28-2006 06:08 AM
CAMRY FAQ ***READ FIRST*** EKam Camry & Solara Lounge 7 07-08-2005 10:05 AM
How to change courtesy light in door and glovebox on 92 Camry fernicus 3rd & 4th Generation (1992–1996 & 1997–2001) 7 02-22-2005 08:20 AM
how do you change rear break light plastic nofear4189 Camry & Solara Lounge 6 12-29-2004 06:43 PM
