using only water as engine coolant - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-28-2006, 09:19 PM   #1 (permalink)
View chesstompowell's Photo Gallery
Canada using only water as engine coolant
Hi guys,
Sorry, I've tried doing a search on this topic to no avail, so here goes:
Is it advisable under any circumstance to use only water for the engine coolant?
chesstompowell is offline   Reply With Quote
Old 02-28-2006, 09:23 PM   #2 (permalink)
View msm20032003's Photo Gallery
ummm NO
msm20032003 is offline   Reply With Quote
Old 02-28-2006, 09:36 PM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Only in an emergency situation. NOt for any extended period of time. IF you have to do it make sure you get it replaced as soon as possible. Here is a brief explanation of why from www.howstuffworks.com .
http://auto.howstuffworks.com/cooling-system3.htm
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 02-28-2006, 09:44 PM   #4 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
just dont do it in below freezing temps, theres a reason why its called antifreeze =)
WhiteRabbit is offline   Reply With Quote
Old 02-28-2006, 09:54 PM   #5 (permalink)
Cressida nut
Gameroom cash: $248945
View kamesama980's Photo Gallery
itll work...but no long trips, no cold weather, no hot weather, and get it right ASAP
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'90 Suzuki VX800
"You don't get to judge me for how I fix what you break"
kamesama980 is online now   Reply With Quote
Old 03-01-2006, 09:08 AM   #6 (permalink)
Gameroom cash: $101605
View kenny1773's Photo Gallery
There are only two downsides
1. corrosion
2. freezing
Otherwise pure water will actually tranfer heat faster than a water/anti freeze mix does.
Yes antifreeze does raise the boiling point of water, but not by much. It is really the pressure added to the cooling system that keeps the coolant from boiling.
Some guys run Redline's water wetter mixed with pure water when they are at the race track - no antifreeze at all in the system.
kenny1773 is offline   Reply With Quote
Old 03-01-2006, 09:29 AM   #7 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
The coolant contains corrosion inhibitors, and lubricant for the water pump. Water does not.
Coolant (EG) actualy lowers the surface tension of the water, and makes it a better 'wetter'
Redline's product is going to do that as well.
What are you trying to accomplish?
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 03-02-2006, 08:56 PM   #8 (permalink)
Canada
Hey thanks guys. I guess I'll stick with my green coolant.
Old 03-03-2006, 12:32 AM   #9 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
there is a big debate about coolant water mix ratios... i like 40%Coolant 60% water in the summer... 60%Coolant 40% water in the winter.
you all also forgot about boiling... the coolant makes it so the water doesnt boil at operating temps.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 03-03-2006, 10:35 AM   #10 (permalink)
CamRY GirL Md
View Camry92LE's Photo Gallery
Originally Posted by chesstompowell
Hi guys,
Actually.. if that's the only thing you got it's no biggy. I would Advise not to though. In the winter and cold temps the water is going to freeze.
*~Jackie~*
Camry92LE is offline   Reply With Quote
Old 03-03-2006, 11:28 AM   #11 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
Actually Kenny is right on that one. The increase in pressure is what keeps it from boiling, not the antifreeze itself. Ever see an engine that sat in the cold with nothing but straight water in it? Its a sad sight. If your lucky it'll just be the freeze plugs that blow out. Saw one back in college that blew out the freeze plugs and cracked the engine block. It dropped to below freezing over night.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 03-03-2006, 11:32 AM   #12 (permalink)
tC
View 95camguy's Photo Gallery
[QUOTE=kenny1773]There are only two downsides
1. corrosion
2. freezing
/[QUOTE]
what he said
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
Old 03-03-2006, 12:55 PM   #13 (permalink)
View camlex's Photo Gallery
Ethylene Glycol also works as water pump lubricant.
camlex is offline   Reply With Quote
Old 03-03-2006, 04:55 PM   #14 (permalink)
Canada
Thanks for the aditional info guys. Much appreciated.
One more question: They recommend a 50/50 or 60/40 or even a 70/30 coolant to water mix. Would a 80/20 or higher be bad for an engine?
Old 03-03-2006, 06:58 PM   #15 (permalink)
View tonyreo's Photo Gallery
Some good information:
http://autorepair.about.com/library/.../bldef-033.htm
tonyreo is offline   Reply With Quote
Can I use Synthetic motor Oil at 5k miles? Meteor_Proof 2nd Generation (2005+) 39 04-07-2006 01:00 PM
Coolant Flush LebaneseCam Camry & Solara Lounge 55 01-27-2006 11:18 AM
Check Engine Light with a side of rotton eggs and water deej Camry & Solara Lounge 3 01-19-2006 10:23 PM
Jasper remanufactured engine (5sfe) cupcakes 3rd & 4th Generation (1992–1996 & 1997–2001) 10 04-01-2005 04:09 PM
auto tranny fluid as engine coolant? andyman61 General Discussion 5 05-10-2004 01:36 PM
