to check for an open circuit you would need to pull the switch and use a multimeter to get an ohm reading. Depending on the meter it will tell you if there is an open in the circuit. Best thing to do would be to check the ones you know are good then compare it to teh bad one. You have to make sure you disconnect the abttery before doing taht though or pull the fuse that controls those switches. You can not put power to an ohm meter or you will possibly fry the meter.
You can get a cheap ohm meter at most parts stores or radio shack, Home depot for 20 bucks or so probably. It should be good enough to help you out.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
