Need help with loud screeching noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2006, 07:28 AM   #1 (permalink)
View stockcammy's Photo Gallery
4th Generation Need help with loud screeching noise
Since the weather has gotten cold (last 3 months) my 2000 Camry has had a loud screeching belt problem. About the same time, my steering wheel wouldn't turn in the morning or after my car has been sitting for a few hours in the cold. I got the power steering pump replaced (ouch!) and the sound went away for about a week. Now it is back, but I have notice one thing, it seems to be worse when I have front defrost on. Now it seems that the air is not as warm as it was. Could it be the compressor, a belt, something else power steering pump related, or just something else? Can I try and tighten the belt by myself? If so, where is the compressor and how do I do it?
Thanks,
Brian
stockcammy is offline   Reply With Quote
Old 03-01-2006, 09:43 AM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
How old is your accessory belt? and is it tightened properly?
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 03-01-2006, 11:21 AM   #3 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
IT is worse when you turn on the defroster because your belt has to work harder to spin the compressor. And you weel doesnt turn because the poewrsteering bump is ran by the belt. Tighten your belt or get a new one. I use armorall on my belts. Keeps them from drying out.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 03-01-2006, 11:33 AM   #4 (permalink)
Darkside Cut Me!!!
To Stockcammy
ArmorAll or any belt dressing is not your solution. Check for good belt at proper tension.
Any dressing you put on at this time will just cause more slipage, which will lead to the belt wearing out even more and breaking.
2004 RX330 Sport
2003 Cam I4 XLE
Old 03-01-2006, 02:11 PM   #5 (permalink)
The serpintine belt was replaced last year and supposedly the other belts. If it is just the tension, how do I tighten it? Does anyone have pictures of which belt and where it is that I will need to check?
Thanks
LOUD buzzing noise at 75+mph ATX_Tacoma 2nd Generation (2005+) 26 03-08-2006 09:07 AM
Help with screeching noise when turning the steering wheel Ghetto2315 Archived Corolla threads 3 01-12-2006 06:11 PM
my Camry 03 makes loud noise from engine room! poraminna 5th & 6th Generation (2002-2006 & 2007-2011) 6 02-23-2005 09:19 PM
my Camry 03 makes loud rattle noise! please help poraminna 5th & 6th Generation (2002-2006 & 2007-2011) 7 02-23-2005 05:35 PM
