Hand brake light Off and on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2006, 03:28 PM   #1 (permalink)
-= CAMRY =-
View pk_kk's Photo Gallery
I've was driving alog yesterday and the handbrake lights keeps going on and off. I assume the rear Shoes are Sticking causing the light to go on. Sometimes in turns I feel a bit of drifting not 100% if it's the snow or the brakes.
http://www.cardomain.com/id/pk_kk
pk_kk is offline   Reply With Quote
Old 03-01-2006, 03:59 PM   #2 (permalink)
Gameroom cash: $304355
Check the level of the brake fluid in the brake master cylinder resevoir. Chances are it is a bit low. Actually remove the cover and look inside. If it is low, refill it to bring the level to the full mark and the light should go off.
Mike
Old 03-02-2006, 08:21 PM   #3 (permalink)
-= CAMRY =-
i dont think it's that..
Old 03-02-2006, 09:39 PM   #4 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
What Mike has suggested is the most common cause. Add some brake fluid, even if it looks okay. If the problem doesn't go away then we'll ask when was the last time the brakes were serviced etc.
It worked fine until I fixed it!
csaxon is online now   Reply With Quote
Old 03-03-2006, 02:52 PM   #5 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
that happened to me, the light actually stayed on, i was pokin round under hood, looked over at fluid resovoir and noticed it was just at or below min., filled it up and BINGO!
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 03-03-2006, 02:59 PM   #6 (permalink)
Gameroom cash: $199835
View swegyptian's Photo Gallery
I say have a look there too. That and the failure of the brake light sensor are the only two that I can think of, and the low fluid happens a good amount more than the sensor dying.
www.swegyptian.com
swegyptian is offline   Reply With Quote
