Yes, it's a tilt wheel. I went to the dealer and looked at their parts dep't blowup of the column and there is no bushing there, only a bearing that looks to be 4-6 inches down in the column and it costs $88 !! I can get a column from a junkyard for not much more than that - so, here's what I did temporarily; I took a rubber grommet, cut it down to fit, lubed it with Lithium grease and shoved it in around the shaft. Then I torqued the wheel bolt down and Voila! It's tight, at least until I can get a column and replace it...
Thanks!
Paul Cockram
