Oil line sizing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-02-2006, 12:02 PM   #1 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
Oil line sizing
Ok this is for the turbo guys, I need to make an oil feed line going from my oil pressure sensor location to my ct26 that has not been clocked or anything unusual. I have read the turbo sticky many times but my case is special because I have higher oil pressure. When I removed my engine balancer assembly awhile back I plugged the oil feed ports to it and now my engine runs substantially more oil pressure and thus I would assume, volume. I am afraid that if I use the regular size feed line everyone else is using that I will have too much oil going to the turbo and I will blow out the seals. Should I use a restrictor in the oil line mabe? What do you guys think? By the way the oil pressure is about 20 psi higher than stock across the board.
Home Page: http://www.cardomain.com/memberpage/506928/1
5S-FE Turbocharged @8psi with 5-speed auto to manual swap
97camryman is offline   Reply With Quote
Old 03-03-2006, 03:52 PM   #2 (permalink)
97camryman's Avatar
I bought a -3 an teflon hose today with aeroquip fittings. Hope it is the right size. Anyone?
Old 03-03-2006, 05:10 PM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
-3 AN for the oil feed works fine. I used -4AN on my setup, which is only a tad bigger (1/16").
You want the drain to be big though. Something like -10 AN or -12 AN.
"Skoolin' the unlearned!"
Old 03-05-2006, 04:12 PM   #4 (permalink)
97camryman's Avatar
Lol thanks, I have the drain way covered My drain line is 1 1/4 inch which is like -20 AN or something. I saw a few people using -4 and I felt that with higher oil perssure -3 would be ok but I wanted to confirm this with someone who actually knows.
How to Turbo the Camry - 5s-fTe tips and information Hamsterman Camry & Solara Lounge 118 09-23-2010 10:43 AM
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 01:37 AM
Synthetic Oil Jaspher Camry & Solara Lounge 96 04-15-2007 12:42 AM
Oil pressure extreme drop on 94 4Runner dutchq 4Runner Lounge 4 10-02-2004 09:05 PM
Help!! Oil Puddle Under Engine Structureboy Camry & Solara Lounge 12 01-17-2003 12:04 PM
