ignition problems please help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-03-2006, 05:08 AM   #1 (permalink)
View cam4me's Photo Gallery
USA ignition problems please help
hi im been reading post for hours and have not found anyone with the same problem i have
i have a 93 camry 4 cyl auto. when i turn the key theres nothing, battary is good
no lights in dash ,no radio or anything door chimes and dome lights are working
any idea what might be wrong?
cam4me is offline   Reply With Quote
Old 03-03-2006, 10:30 AM   #2 (permalink)
Moving Forward
View Cyorke's Photo Gallery
does the starter click or anything when you turn the key over. The most common problem with starters on Toyotas is the the starter contacts or brushes go bad and you will hear a click when you try to start teh car. Most people will jsut replace the starter at this point but you can replace the contacts for considerably less. The contacts will probably cost you less than 20 bucks plus labor to pull the starter and install the contacts. Where a starter is probably going to be pushing over 100 bucks.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 03-03-2006, 10:41 AM   #3 (permalink)
CamRY GirL Md
View Camry92LE's Photo Gallery
I'll Have to agree. Sounds like the Starter.
*~Jackie~*
Camry92LE is offline   Reply With Quote
Old 03-03-2006, 11:38 AM   #4 (permalink)
Moving Forward
oh my bad I thought it said the lights and all were working. I missed that one word "no".
Ok then yeah You need to be looking at fuses. There are so many that it could be. You really need to check any that have something to do with the starting of the car. There should be a large fuse in teh under hood box for the alternator. that one can cause it not to start. anything that says start or ignition. I cant remember for sure but I thinkthere is also a fulsible link in teh positive battery cable at some point. I seem to rememebr having on eof those go out when I was a Toyota mechanic.
COuld possibly also be the ignition switch itself since you say the dome light nd door chime are working.
Chris
Old 03-03-2006, 12:06 PM   #5 (permalink)
Gameroom cash: $199835
View swegyptian's Photo Gallery
Try jump starting it too, or using a voltmeter on the battery when you try to start it.
www.swegyptian.com
swegyptian is offline   Reply With Quote
Old 03-03-2006, 11:28 PM   #6 (permalink)
Dave's
Gameroom cash: $122050
View Dave's's Photo Gallery
My wife's '92 once had everything working except the starter. I called AAA to take it home so I could change it. I had tried jumping it with my '93 and still nothing. But when he hooked up with his high power alt and battery array, varoommmm. New battery and never had another problem. Not saying that's it, just don't jump into anything before you're sure it's not something simple.
Dave's is offline   Reply With Quote
Old 03-03-2006, 11:32 PM   #7 (permalink)
View Novice_cardude's Photo Gallery
Also check the connections to the battery. I've seen some really wierd stuff form bad/dirty connections...
Novice_cardude is offline   Reply With Quote
Old 03-03-2006, 11:38 PM   #8 (permalink)
View Gary_602Z's Photo Gallery
First thing I would check and also the easiest! Plus it needs to be done anyway!
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 03-04-2006, 10:29 AM   #9 (permalink)
View CamryBoy92's Photo Gallery
does cold weather have something to do with it....when its cold here and i have a sri it seems like if i try to just turn the key the car just clicks but if i turn it to the second spot where the rents are blowing and then wait ffor the radio to come on the car starts fine???idk maybe theirs somthing wrong with my car
CamryBoy92 is offline   Reply With Quote
Old 03-07-2006, 03:46 PM   #10 (permalink)
View CamNDN's Photo Gallery
ignition
One thing I would check is the positive cable from the battery to the starter itself. Grab the cable at the battery and follow it down to the starter, looking for places that the cable might have worn out and be touching metal.
Sometimes on an auto the harness that holds the battery cable away from the engine will break and the battery cable will touch the engine. This won't present a problem for a while, not until the heatshield/insulation on the cable gets worn out from touching the hot engine block.
Once this happens though the cable will get welded to a hot engine block. Everything is fine up until you go to start the car. Up until the key is turned over the accessories (headlights, radio, power windows/mirrors/locks) can still work properly. This is because the electrical circuit to the starter is not open yet. But when you turn the key to start the car the circuit is opened and it is at that point that the circuit shorts itself out and the car won't start and accessories go off. But when you stop trying to start the car and stop turning the key in the ignition the circuit is closes and the accessories will work again. So try to turn on the radio and then start it and see if it goes off when you turn the key but comes back on when you stop turning the key.
Look for the positive wire from the battery to be welded to the engine block. Pull it away from the engine block and put electrical tape on the wire along with a new heat shield. Also put wire back in a secure harness.
CamNDN is offline   Reply With Quote
Old 03-07-2006, 04:17 PM   #11 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $910327
iTrader Score: 59 reviews
Same advice here, clean your battery terminals and make sure their tight! If your absolutely sure your battery is good!.....They sometimes sell bad ones!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 03-08-2006, 09:52 PM   #12 (permalink)
View marc780's Photo Gallery
I have to vote with Cyork on the ignition switch maybe being the problem, from your post heres what i see: No starter. No radio. (These go through the ignition switch). YES door chimes. YES dome light. (These Do NOT go through ignition switch!)
Try and jump your starter, use a remote starter switch if you can borrow one. If the starter will turn, this could help point to a worn ignition switch as being the problem. Try wiggling the key as you turn it and see if anything happens. Since its not just the starter not turning but whole bunch of things not working, maybe you should just change the switch or at least access the igntion and try shorting the contacts to see if you can make any of the dead stuff work, then you will know for sure.
Old 03-08-2006, 10:01 PM   #13 (permalink)
View supersport's Photo Gallery
ignition probelm
blown fusible link
supersport is offline   Reply With Quote
Getting alarm to chirp procedure - here it is JJMARINE 2nd Generation (2005+) 27 07-13-2007 04:06 PM
1983 Celica GTS - Having Ignition problems wolfdefender Celica Forum 3 08-24-2005 04:49 PM
Help please!! Ignition problems!! stgranger MR2 Forum 6 07-16-2005 09:34 PM
Using "Search" All day Here. '89 3SFE Ignition Problem(s) sdhartney 1st & 2nd Generation (1983–1986 & 1987-1991) 4 10-07-2004 08:00 AM
Ignition or starter problems spills1969 Hardcore Tech and Competition 2 01-18-2003 11:02 AM
