I live in Chicago's northwest suburbs. I also have a 98 Camry XLE 4 cylinder 5SFE engine. Your car is OBD2. Just make sure your check engine light (MIL) is not on. They will first check your gas cap for sealing and holding pressure and then plug in to your OBD2 connector. If no codes are present, you have passed the test. They no longer run a dynomometer test on OBD2 cars. Also, you can not just remove the light in the dash to cover up a check engine light. They will turn the car's key on first to make sure the check engine light lights up, before plugging in to the connector.
Mike
