abs light on? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2006, 10:18 AM   #1 (permalink)
View netherland24's Photo Gallery
Question abs light on?
well yesterday i decided to go ahead and rewire all my battery cables. starter,alternator, fuse box and after i was done with that i had my ABS lights come on everything else is fine just that? what could it be? i checked all my wiring again.
thanks for any help
forgot to mention this is for a 2001 carmy Le
netherland24 is offline   Reply With Quote
Old 03-04-2006, 11:49 AM   #2 (permalink)
no ideas? anyone? fuse? take it too a shop to reset?
Old 03-04-2006, 10:43 PM   #3 (permalink)
wow no help at all? come on guys i would appricate the help.
Old 03-04-2006, 10:46 PM   #4 (permalink)
not your average bear
View justchillinjefe's Photo Gallery
there is a thread involved with resetting the ecu using the diagnostic port. This may not work and you would have to check your ecu at Autozone or somethin. Hope this helps.
justchillinjefe is offline   Reply With Quote
Old 03-04-2006, 10:55 PM   #5 (permalink)
i will check the ecu at autozone... but i am still curious why just changing battery cables would do that? i know we removed teh fuse box and could it be that? just a blown fuse or loose?
Old 03-04-2006, 11:29 PM   #6 (permalink)
im a chong.
View thcfortified's Photo Gallery
trying putting it in drive, jam on the gas, then slam on the brake.
try it a couple of times and see if the light goes off.
Toyota Tech.
give me all the diag, check engine lights, warranty work, i dont care. i dont to make 40hrs. i love guaranteed time.
thcfortified is offline   Reply With Quote
Old 03-04-2006, 11:46 PM   #7 (permalink)
Nad1370's Avatar
View Nad1370's Photo Gallery
Have the code scanned first.
Then we'll know were to start looking.
Nad1370 is offline   Reply With Quote
Old 03-05-2006, 12:35 AM   #8 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
scan the code for sure. getting the code for ABS may be a bit tricky so good luck.
If you are thinking about fuses so much why not just go out and check it? Takes 17 seconds to do.
nodrogkam is offline   Reply With Quote
Old 04-24-2006, 06:10 PM   #9 (permalink)
View gwar28's Photo Gallery
Im having the same problem but my trac off light is blinking as well. I went to Autozone and no codes came up. Any Suggestions?
gwar28 is offline   Reply With Quote
Old 04-24-2006, 06:14 PM   #10 (permalink)
nodrogkam's Avatar
welcome to TN.
Does your camry actually have Traction Control or is it just the light blinking?
Also did this happen after doing anything special?
The first thing i'd do is detatch the battery for 15 minutes to see if that clears it up.
Old 04-24-2006, 06:21 PM   #11 (permalink)
Thanks for your help. I think it has Traction control I just bought it. Ill try that and see. Which diagnostic port should I use the one in the engine compartment or underneath the dash.
Old 04-24-2006, 06:49 PM   #12 (permalink)
nodrogkam's Avatar
you willa ctually need to try both. For the ABS code readout the one in the engine compartment was used i believe.
Old 04-25-2006, 03:37 PM   #13 (permalink)
I ran the code inside and it came up blank. I took off the negative battery terminal and the light is still on. I went to auto zone and they don't have the right scanner for the engine compartment hook up, any suggestions on where I could get one?
Old 04-25-2006, 03:45 PM   #14 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
where is the port in the engine compartment on an 05 I4? just wondering.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 04-25-2006, 05:33 PM   #15 (permalink)
nodrogkam's Avatar
gwar yeah you're going to need to the one in the engine bay the.
but you dont disconnect the negative terminal...that doesnt do much. You need to disconnect the positive terminal.
Camralon: look in your engine bay for a small black box with a cover that says Diagnostic.
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
ABS warning light ON!!!!!!!!! szeyee Archived Corolla threads 2 10-04-2005 01:12 PM
ABS light stays on - 94 Corolla bertherr Archived Corolla threads 2 06-10-2005 07:10 AM
95 SE abs warning light, pls help! c95se 3rd & 4th Generation (1992–1996 & 1997–2001) 9 01-07-2005 12:40 PM
ABS light comes on profuse007 Camry & Solara Lounge 10 08-28-2004 10:22 AM
