Brembo Sport Rotors, what pads should I use??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2006, 09:59 PM   #1 (permalink)
View 99Camry99's Photo Gallery
Question Brembo Sport Rotors, what pads should I use???
I have cross drilled Brembo Sport Rotors in the front of my 1999 Camry. I'm getting a high pitch squeak. I tore my brakes apart last week and lubed up everything but the pads. It still squeaks so I know its the pads. I've had these Brembo rotors & pads for about a year and it started squeaking about 4 weeks ago. What do you recommend for pads that I can use with these rotors? And would different pads even improve my braking? Thanks.
99Camry99 is offline   Reply With Quote
Old 03-04-2006, 10:13 PM   #2 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
You had the pads for about a year? were the pads and rotors brand new when they were installed? That would insure proper break in.
Anyways its been a year i recommend getting some Akebono Ceramic brake pads. No brake dust, high temp fade resistent, long lasting, quiet, and dustless. Its what i personally use in front with my cross drilled brembos. I need to get something for the rears as my rears make noise... (i dont have akebono in the rear). DO NOT get the RAVEN pads from Midas...those are what are causing the noise. My personal mechanic recommends to use Toyota OEM parts as these cars tend to break faster if you dont. At any rate i just feel the OEM pads work best.
You can go for Hawk Pads too if you have a little more money to spend.
nodrogkam is offline   Reply With Quote
Old 03-05-2006, 08:14 AM   #3 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285280
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
hawks are nice, I like the akebono's myself though
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 03-05-2006, 11:44 AM   #4 (permalink)
-= CAMRY =-
View pk_kk's Photo Gallery
I've encountered the same problem after installing cross-drilled rotors. I simply changed my brake pads to PBR Ceramic pads. The hard surface on cross-drilled rotors require a hard surface brake pad. Also check the metal plates that go on, Those are for noise reduction and one is for detecting your brake pad tread and squeals when the tread is low. i'm 100% sure if it's not the brake pad it's those metal plates making the sounds.
http://www.cardomain.com/id/pk_kk
pk_kk is offline   Reply With Quote
Gen4 brake rotors and pads replacement Luc Hardcore Tech and Competition 5 03-06-2012 03:40 PM
Suspension, Brake Pads, Rotors, and Exhaust All Shot - Need Advice TradeViceroy Camry & Solara Lounge 6 10-26-2005 03:06 AM
Brembo rotors and Axxis Metal Master Pads kbg4 Archived Corolla threads 0 06-08-2004 05:11 PM
