IMO Brembo are good, but overpriced
IMO the slotted and/or drilled rotors are NOT worth the money, I have owned both and they do nothing to improve braking in even agressive street driving
YES - the steel braided lines will increase the pedal feel and modulation
For bang for the buck, I really like the Raybestos PG Plus rotors (you can get them from
www.rockauto.com)
I like the Hawk HPS pads, and the Raybestos PG pads, Akkebono, the Axxis Metal Master pads and a couple others I seem to be forgetting. AVOID EBC pads for street use, again, simply not worth the money, the performance isn't there.
A good pad on a quality blank is all you need unless you are racing on a track. There is a good bit of difference in the pads I listed above. Raybestos and Akkebono would be OEM replkacements and for normal street. The Hawk would be a step up, the Axxis would be a step up again.
