Need an explanation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-03-2001, 09:01 AM   #1 (permalink)
Toyota Nation Wanderer
View Camry726's Photo Gallery
Ok, here's my problem. When I'm racing my gen3 camry or just flooring it on a lonely street, by the time I rev it to bout 5000revolutions, I hear this ssssssssss sound coming from the engine. Might be a stupid question, but I just wanted to know what's making that noise.
Camry726 is offline   Reply With Quote
Old 12-03-2001, 09:04 AM   #2 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700165
iTrader Score: 6 reviews
View EKam's Photo Gallery
You probably got a turbo under the hood without knowing it. :wink:
I think this is normal though, the Camry V6 motor likes to scream (those of you who went to dyno know what I'm talking about).
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 12-03-2001, 09:07 AM   #3 (permalink)
View benyu's Photo Gallery
Time to get an oil change.
- Know your limit, and perform to the limit
benyu is offline   Reply With Quote
Old 12-03-2001, 09:26 AM   #4 (permalink)
Dang, an oil change already. My last oil change was last month and I've only gone about 2000miles. Maybe I'm driving it too hard?
Old 12-03-2001, 10:12 AM   #5 (permalink)
To be honest, I can feel the engine noise getting louder 3000 km after oil change, and I am not driving very hard either. So probably try the synthetic oil next time (I'll be using Mobil 1 soon too).
Old 12-03-2001, 10:23 AM   #6 (permalink)
View speedemn's Photo Gallery
Switching to synthetic on a car that's been using regular all its life isn't a good idea. It depends on how many miles on your car though. How much does yours have?
2003 BMW 540i 6-spd
2008 Toyota Rav4 Limited V6
2005 Mazda 3 Sport GT 5-spd (just sold)
1995 Nissan Maxima SE 5-spd... Best ET: 13.8... Best trap: 99mph (Gone)
1993 Toyota Camry LE (Gone)
speedemn is offline   Reply With Quote
Old 12-03-2001, 11:13 AM   #7 (permalink)
EKam's Avatar
I'm sure he can try something like synthetic blend instead of going all out to full synthetic.
Old 12-03-2001, 11:15 AM   #8 (permalink)
Yes there are semi-synthetic oils made that are meant for older engines. But it depends, Ben might even be able to use synthetic. Isn't his car pretty new?
2003 BMW 540i 6-spd
Old 12-03-2001, 11:30 AM   #9 (permalink)
37K now.
Old 12-03-2001, 12:04 PM   #10 (permalink)
View erfan's Photo Gallery
Hi,
I have 94k on my Lexus Es300 and i want to know if i can use full synthetic? It has been using penzoil and other petroleum based oils all its life, what are the complications on doing the conversion?
Thanks
erfan is offline   Reply With Quote
Old 12-03-2001, 12:44 PM   #11 (permalink)
My car is a 3rd gen 94 Camry with 134,476 miles on a I4 engine. I've bought this car used from someone else.
Old 12-03-2001, 01:35 PM   #12 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
View Jzs147-RR's Photo Gallery
Ok what you guys have got to do is try the oil first.I went to synthetic at 55 000KMa nd i had no problems.On a higher milage car its better to try the oil out and see if you loose oil after a couple weeks,the only thing that can happen is that the oil level will drop and then you just need to add more.But if it keeps going then its time for a semi blend that will not burn or leak.In most cases the oil will not leak in a well maintenained engine but after a while some oil can seep out of gaskets and your piston rings.I would not do it on a 150 000 mile car but anything lower might be ok as long as its well maintained and has good compression in the cylinders.(If it leaks from the gaskets go back to normal Dyno oil)
5sfe powered turd ...
Jzs147-RR is offline   Reply With Quote
Old 12-03-2001, 01:38 PM   #13 (permalink)
Benyu and Erfan... the suggested way to use synthetic oil on your car is:
Buy brand new car
Use regular oil for the first tuneup
Switch to synthetic on the second tuneup
So basically you make the switch before 10,000 kms. That is the BEST way to do it. However if you want to switch later on, it is all at your own risk. Nothing bad will happen in most cases, but are you a gambler? :smile:
2003 BMW 540i 6-spd
Old 12-03-2001, 02:34 PM   #14 (permalink)
what can happen?
Old 12-03-2001, 02:38 PM   #15 (permalink)
Gambler...gosh sounds so serious!
Haha, anyway I'll consult the technicians at Toyota first.
_________________
True Love Never Runs Smooth.
<font size=-1>[ This Message was edited by: benyu on 2001-12-03 15:39 ]</font>
who's cars do we like the best! (and explanation) martingouda Off Topic 18 07-18-2002 11:28 AM
