Originally Posted by JohnQ
This might be a stupid question but a little help would be nice.
How much does it cost to change new timing belt , new brake pads ,and new exhuast system?
95camry 4cynlider
this isnt a dealer price but just a quote for you i work at Meineke, Brake Pads.......hahah gotta love this one, 4 wheel disc? front wheel disk will run you about 70 bucks labor thats including machining the front rotors(if they are still in spec it is 1.024 :o ) pads will be about another 85 or so with shims, plus they would probably sell you a clean and adjust the back if of course the shoes are good and wheel cylenders arent leaking 25 for clean and adjust
exsaust...........on camrys never goes bad beside the front pipe.....on 94 and up models came with the catalytic made into the front pipe...runs about 550, cat back is roughly 450 if dameged by an accident or something, timing belt, cam seal, crank seal and water pump should be all done at once and thats about 450
this is all in Us dollars prices and thats pretty close
good luck
