Originally Posted by swegyptian
Probably not without extending the leads. When you flip it, they might not reach over the top of the battery.
That is the problem that I had, although in retrospect, it would have been easy to bend the clamps, which I had to do anyway, when they didn't really fit over the edge properly anyway.
It was really easy to re-route the wiring (once you cut all the tape off of the plastic channel that contains the wires), and you DO NOT have to extend the leads, with the exception of the 8-gauge wire (+) which goes directly to the starter. It is a separate cable anyway, so run to the autoparts store and get a universal battery cable that is slightly longer, and you will be fine.
Search, there heve been several recent threads on this.
