Fuel pump rewire. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2006, 10:41 AM   #1 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
Fuel pump rewire.
So in my quest for boost, I need a new fuel system. I am converting to a return type system with an external regulator that is boost dependant and a new fuel pump to keep up with the demand of the new injectors and all. Basically it looks like in our cars, voltage is varried to the fuel pump. At idle and low throttle cruising the pump gets less voltage than at higher throttle. Either way it will make for tuning issues later. I cam eto three conclusions;
1. Leave it how it is and throw in a Walbro 255lph return system and injectors
2. Make it 12 volts constant even at idle with the walbro and reg and injectors of course,
3. Try and rig it to supply low voltage at idle but full voltage at high load with the same walbro, fuel reg, injector setup.
Will I hurt anything if I just make it run at 12 volts all the time? Will a stock return line off a gen 3 work fine for my new return line? (after bypassing in tank reg of course)
Input please...
Home Page: http://www.cardomain.com/memberpage/506928/1
5S-FE Turbocharged @8psi with 5-speed auto to manual swap
97camryman is offline   Reply With Quote
Old 03-08-2006, 12:31 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
No.
Most likely not. Different length, bend angles, and such.
You can buy hardline and make your own or use stainless steel braided hose.
"Skoolin' the unlearned!"
Old 03-08-2006, 09:46 AM   #3 (permalink)
97camryman's Avatar
Originally Posted by 88 LE
No.
Yeah I already know the stock line wont work location wise, I was just not sure if its diametr was big enough, Either way the first part will be aeroquip -6 AN stainless hose from rail to regulator then reg to hardline. I will probably just make a hardline since I cant find any gen 3's in the local pick n pull.
'89 Eng swap, fuel pump? Donald Tercel, Paseo, Starlet, and Sera Forum 15 03-19-2005 05:17 PM
help newbie save '85 with fuel system problem leiniesred MR2 Forum 0 02-28-2005 09:49 PM
Fuel pump requirements for 5psi boost (carb'd 4a-c)? O 16581 72452 5 Archived Corolla threads 4 03-17-2004 12:00 PM
