Air Intake/Radiator Blockoff questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2006, 10:21 AM   #1 (permalink)
View matt swindell's Photo Gallery
Some of you guys may remember a few weeks back I was asking about making a grill intake, well I have basically figured it out. A buddy of mine replaced his radiator, so I took the old one, cut it up to size and am going to box off the back of it. This will be mounted in/behind my current grill (all cut up, only frame left), but it will be blocking off the top part of the radiator.
My question is, how much will it hurt the car to have the top few inches of the radiator blocked off? Also are there any modifications needed to make a new intake work, aside from removing the airbox and hoses and running some piping to it?
This is on a Gen 3 Camry by the way. Also, just incase anyone feels the need to tell me, I don't care if you think I am "posing" or being a ricer, by having something that looks somewhat like an intercooler in front, so no need to tell me.
matt swindell is offline   Reply With Quote
Old 03-08-2006, 10:26 AM   #2 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
hurting!no, there is no mods required for an intake. just remove the stock and replace with the new.
johnnyzee is offline   Reply With Quote
Old 03-08-2006, 10:36 AM   #3 (permalink)
So you are saying it wont hurt the radiator/cause overheating?
Thanks for the help and being so quick about it, anyone else?
Old 03-08-2006, 01:29 PM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
how does a radiator cool air? =(
(this is a huh? question as if i think yoreu doing it how i think you are, ... BIIIG pressure drop)
terrastrife is offline   Reply With Quote
Old 03-08-2006, 08:24 PM   #5 (permalink)
The radiator wont actually be cooling it, the piece of a radiator I'm using will be used for the front of the intake. It will be blocking off the cars original radiator, and will be cooler air because its coming from the front of the car, instead of from the engine bay.
Old 03-10-2006, 10:16 AM   #6 (permalink)
Problem I just ran into, while mocking it up, I was looking around and it seems my original spot to run the intake tubing isn't there. So does anyone with a Gen 3('93 V6) know of anyway to run a pipe, between 2-3" if possible, to the front of the car, infront of the radiator??
Thanks a lot for all the help so far!
Old 03-10-2006, 01:42 PM   #7 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
go behind the headlight, or go under fuse boxes through hole, and route from there...
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 03-10-2006, 01:50 PM   #8 (permalink)
Axel Kain's Avatar
theres a hole at least 2.5", the flat top of my filter is pointing right at it.
this is a 92 V6
Short air intake question rabinny Archived Corolla threads 55 11-25-2005 08:01 PM
Open air filter or panel air filter?? Della D. Turbo MR2 Forum 7 10-18-2004 06:04 PM
Air Time Your Uncle Moe Camry & Solara Lounge 15 07-29-2004 12:58 AM
air fuel ratio questions... HPR Archived Corolla threads 12 12-02-2003 07:10 AM
filter question! boroEF Hardcore Tech and Competition 14 04-21-2002 07:07 PM
