Code P0110? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2006, 08:14 PM   #1 (permalink)
View JohnSWA's Photo Gallery
Code P0110?
Hey guys, I've been going crazy troubleshooting a problem. I so far I've changed the fuel pump, fuel filter, TPS. I've got spark and I definitly have fuel! (I opened the fuel line from the filter while turning over... fuel everywhere) I borrowed a code scanner and now I have code P 0110. I pulled the EFI relay while checking the code so I'm guessing that's what this code is for. Funny thing is that I put the relay back and I still have the code!
I sure could use some help here. I might just change the relay since I've changed just about everything else!
Thanks!
JohnSWA is offline   Reply With Quote
Old 03-08-2006, 09:01 PM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
On the right side of your airfilter box is a round rubber grommet with the Intake Air Temperature sensor (IAT) in it. Unplug and clean it and the connections.
The PO110 indicates an open or short in the air temp circuit or the IAT sensor itself may be bad. If the IAT sensor fails then the ECM goes into fail safe mode.
You can resistance test the IAT sensor in a pot of hot water with a thermometer and an OHM meter. At 68 degrees your should read 2-4 kohms. At 104 about 1-2 kohms.
This is no doubt related to your earlier posted problem.
It worked fine until I fixed it!
csaxon is online now   Reply With Quote
Old 03-08-2006, 09:59 PM   #3 (permalink)
Well, I'm ready to throw in the towel. I've cleaned the IAT sensor and gave it a whirl and it still won't fire up! I just know when I take it to a "real" mechanic, he's going to find something simple! Grrrrrrr! I think my wife will like me a lot more once I have it towed to a good shop. Now to find an honest shop!
Old 03-09-2006, 11:14 AM   #4 (permalink)
Cleaning a "bad" sensor won't help it. It's just an attempt to clean and check for poor connections and corrosion before resistance testing it to determine if the sensor is bad.
The Toyota guy will plug in his advanced OBDII scan tool and troubleshoot it in 1 minute.
The PO110 indicates an open or short in the air temp circuit or "the IAT sensor itself may be bad."
Good luck!
Old 03-09-2006, 01:51 PM   #5 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
The car should still start up and run with a bad IAT sensor. You probably have more than one problem.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 03-09-2006, 04:18 PM   #6 (permalink)
Somebody shoot me! I just bought a new IAT sensor. I was sooooo looking forward to trying it. I figured that a tow truck would cost at least a hundred bucks to tow it 5 miles, so what's another $60? I'm about to go nutz!
Old 03-09-2006, 04:30 PM   #7 (permalink)
I guess you didn't resistance test the old one? Stop guessing and throwing parts at it! Diagnosis first.
I'll be heading back to San Diego in a few months. Put some more parts on it and I'll take it off your hands!
They take the part back if you look sad and dejected.
Old 03-09-2006, 04:44 PM   #8 (permalink)
You're right I should have tested it. Last night I was so frustrated, that I didn't read the test through! Pretty simple test! I'm sure that Autozone would take the part back, but I bought this one from the dealer. Oh well, we'll see what happens.
Old 03-09-2006, 08:17 PM   #9 (permalink)
Of course, that didn't change anything. It's off to the shop for sure now! Lesson learned.
Old 09-15-2009, 10:16 PM   #10 (permalink)
View SKarpenz's Photo Gallery
I really hate to bring this up from the dead, especially as my first post. BUT WTF WAS THE PROBLEM!?
This is EXACTLY what my '01 Tacoma is doing (2.4 5sp) and I'm about to light it on fire out of frustration. P0100 code and P0110 code. It just did it out of the blue and now I can't get sh*t out of it. Has gas, has air, has fire. WTF.
PLEASE help me out here, I cannot afford to take it somewhere.
http://www.tacomaworld.com/forum/tec...l-i-think.html
SKarpenz is offline   Reply With Quote
2000 Toyota Corolla VE Trouble Code help??? hssaini Archived Corolla threads 3 07-28-2006 10:02 PM
why am i getting code 52 eyz closd MR2 Forum 7 01-10-2006 08:36 AM
Camry Color Code Confusion jck91camry Camry & Solara Lounge 7 06-22-2004 12:19 AM
Check Engine light Code 25 & 26, please HELP!! xaznxeclipsex MR2 Forum 0 06-01-2004 08:46 PM
ecu trouble code Nx2k Archived Corolla threads 1 02-12-2003 06:36 PM
