Try these
1. The rotors may not have been finished right. Sand em a little with fine emery clothe for a minute or two, then clean with brake cleaner.
2. Like Mike said, make sure that anti squeal shims are in place if they are supposed to be.
3. Get some anti squeal goop from the auto parts store. This stuff is a gluey substance like thin silicone sealant in texture. Remove the pads and lay them lining side down and apply this goop as directed on the back of the pads. reassemble brakes.
4. Check to make sure your caliper pistons are not sticking. If you jack up the car and try and turn the wheel, they should spin more or less freely with just a little scraping from the pads. If they turn hard and seem hot after driving, you might have sticky pistons and need to fix calipers.
5, Make sure the slider pins in the calipers are clean and greased with high temp brake grease. The pins allow the caliper to slide with the motion of the piston and pads. If they are dry and sticking, this could affect brake noise.
