simple poll, for those who have clunking noises in suspension (rear)
choose ur option.. that way we can see if the clunking noise is because of not having that rubber insulator.
the rubber insulator is the large rubber ring that goes on top of the strut spring plate before you place the spring coil on it... u know where you sit your springs on the strut ? that plate ? on the stock setup, theres a rubber padding that goes on it before you put the spring on..
i know the clunking can be many other things but i just wanted to run this poll and see if it might be because of running wihtout the rubbe rinsulator
