3vzfe tranny's <----note the 's' - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2006, 08:48 PM   #1 (permalink)
View Tacoma_Kyle's Photo Gallery
It would be nice to get some good solid tranny input. By the way this is in the US if there is a difference.
What is every MANUAL tranny (well transaxle...aka front wheel drive) that will bolt straight up to a 3vzfe. I have some blurry input so far.
From my understanding:
I have READ that the camry/ES300's 3vzfe's will bolt up to MR2 turbo transmissions, but apparently not the non turbo's. The trannys that come from the 3sfte's, or like 90-on later to like 00 or 99 MR2's. I have also read that 1mzfe's do NOT have the same tranny bolt pattern as 3vzfe's. But I have heard that those (1mz) bolt to the MR2 trannys listed above. But that info just written doesnt make sense (A bolts to C, B bolts to C, but A doesn't bolt to B). The 91-93 Camry/ES300's had manual options as I recall, so that is solid. But not the 94 to 96 (1mz anyway). Later there was.
I need solid input! Like will a 3vzfe motor bolt to a 2vz tranny? Would it stand up to it ok?
I am to obsessed with my tacoma 5VZ to put a 1mz motor in my buggy (eventually). Wiring wouldn't be as much fun with that particular system either I have been informed and 5VZ's cost too much lol.
Once again I NEED SOLD INPUT!!!
Any help would be much appreciated. Engine:3vzfe, tranny-?
Tacoma_Kyle is offline   Reply With Quote
Old 03-10-2006, 01:44 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
you got it right.
all the i4/v6 tranny options will 'bolt up' (less a bolt or a different flywheel thickness or linkage) but the i4 ones will not hold the v6 power for very long.
in general, get the newer v6 tranny it will be stronger and sync better, a 2vz manual will bolt up but it is weaker.
its not that they DONT WORK, they do, but they arent strong as the v6 boxes.
also remember the v6 boxes have taller ratios.
terrastrife is offline   Reply With Quote
Old 03-10-2006, 02:16 AM   #3 (permalink)
Gen2 Camry Wagon Czar
TWHansen's Avatar
View TWHansen's Photo Gallery
2nd Generation
Just for reference, what would be a good manual to replace the auto in my '91 Camry V6?
Between my friends and I, we've owned over 16 Gen2 Camry Wagons. And we want more.
TWHansen is offline   Reply With Quote
Old 03-10-2006, 02:10 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ E153.
Search for threads by jetspeedcamry for more info. He did the swap on his gen 2.
"Skoolin' the unlearned!"
Old 03-10-2006, 02:15 PM   #5 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
also ratko
http://www.tt-cc.com/ratko/swap/index.html
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Engine swap (3vzfe) by Ben-RR & me mox Camry & Solara Lounge 18 11-28-2006 12:43 AM
Is The 3vzfe Engine Compatable With 5sfe 5 Speed Tranny? skyliner650 3rd & 4th Generation (1992–1996 & 1997–2001) 11 02-17-2006 01:59 PM
5SFE > 3vzFE > 3vzfe supercharge or turbo in future? BuDDHa510 3rd & 4th Generation (1992–1996 & 1997–2001) 8 05-03-2005 11:29 AM
Internals of 1mzfe and 3vzfe, are they interchangeble? simoh 3rd & 4th Generation (1992–1996 & 1997–2001) 2 07-21-2003 10:41 AM
